Blazer Trailing Arm Suspension
I very rarely come to this side of the forum since I do not own a Blazer. But what peaked my interest is that the 69-72 Blazers have 104” wheelbase. Coincidentally, my 1973 P10 wheelbase is 102”. The 1973-1987 Blazers have 106.5” wheelbases.
My P10 has leafs and I really wanted to do the trailing arm swap. But when I look at the frame and length of the arms, the crossmember would literally be at the back of the tranny. For the guys who have done the conversion, where exactly does your crossmember sit in relation to the tranny? Did you have to modify the trailing arm length? I’m assuming with the very similar wheelbases, the crossmembers would be in the same location for a Blazer/P10. Everyone says the Stepvans are on the same chassis as the SB trucks. Well I’ll tell you that’s not the case. I have a 67 SB and the frame dimensions are not the same as the P10.
Customization is what you want it to look like -- not what other people think it should look like |
Re: Blazer Trailing Arm Suspension
I have been considering this for many years, but I don't like the bars that keep the rear end centralized. With a leaf spring suspension I wouldn't have to worry about it
Trialing arms could be made for the demension you want, heck its only sheet metal, or bars... The crossmember that attaches the arms to the frame rails could be used and built off of that, but how do I get rid of the ugly transverse rods? Maybe, Ill start sourcing parts and see how it fits up with 4WD
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
![]() Join Date: Jun 2002
http://67-72chevytrucks.com/vboard/s...=635605&page=2
post 34 has 2wd blazer frame dimensions Good luck, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
Thanks Rg
#5 | |
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
Goes here no trans cross member
