11-21-2018, 06:22 PM | #1 |
Gas tank filler neck mod/swap
Hey guys, has anyone bought a new metal gas tank kit, which I believe most or all come with the wrong filler neck attached? I want to swap my old filler neck on the new tank. Has anyone done this that can give me some pointers or suggestions on how best to do this?
11-21-2018, 09:13 PM | #2 |
Re: Gas tank filler neck mod/swap
I took the tank and the filler neck to a shop and he welded it on. Didn't cost much. It has two bolts so no worries on orientation. Looks like the original is bolted and then maybe leaded.
11-22-2018, 10:11 AM | #3 |
11-22-2018, 10:30 AM | #4 |
It's soldered on with soft solder....remove the nuts and heat it up.....it will come right off.
clean both surfaces well....remove any paint or rust that might be on the new tank...apply a generous amount of flux and solder it back on.....or take it to a radiator shop....they can do it.
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
11-22-2018, 03:06 PM | #5 |
11-22-2018, 03:45 PM | #6 |
" where did you get your tank? "
I got my tank from a nice guy here on this board. He put a new everything in his blazer and decided to go with a brand new tank. His old tank was fine, but he took the filler neck off it. So I found another guy here with a filler neck for sale and bought that. |
