12-04-2018, 12:11 PM | #1 |
C10 Collector
Crew Cab Build
There have been alot of crew cab posts lately, here's my rendition. Rather than just welding a truck back onto a burb I am taking the time to go with a more oem approach. Final assembly will be done with a Pro Spot Spot Welder. Due to the differences in the roof structure I think it is actually easier to stretch a truck cab and install b-pillars. But I already have a burb with a trashed back section so I will be doing extra work to put the correct roof structure in it.
This is the rather complicated roof structure of a suburban and why the roof is taller This truck cab has some of the worst rust I have seen in the roof/gutters. Luckily I dont need that part. It basically peeled off Windshield removed The Dash was perfect save for a switch installed in left side so I removed it and saved as well. With the spot weld cutter warmed up I started tackling the inner roof. My goal is to remove it at the factory joints and save it. Maybe stretch it to go back in or make a new one. Either way I need a starting point. Top of windshield drilled and removed(it rusted through at sides) Not sure if this upper A-pillar reinforcement is in the burb. Will find out soon All drilled. Getting the back loose With a little wrestling you can get it to this point Parts Pile. Not too much rust in the inner, will repair Scalped Next up will be cutting the upper door jambs, floor and removing the rear section of the cab. Probably pull the gutters as well. You can see here the upper jamb spot welds to the a-pillar section and b-pillar section. just need to make it longer. Also picked up another burb B-pillar from a member here. Going to disect this one and make patterns to make future B-Pillars. I have some ideas and plans on low-production stamping some of the pieces. Got a little time to work on the cab again. Cut across the floor and cut the upper jamb pieces loose. I now have the back of the cab rough cut and ready to start fitting to the burb. Post #2 will be the disassembly of the burb clip. Last image for Post #1. Moved some things around and put the two players in close proximity.
///Ryan 1972 Chevy C-10-Bagged, Blown LT1, 700r4, Suicide Doors 1967 GMC- SC & Cam'd 4.8, built 4l80, 3200 stall, posi, 4.10 1967 Chevy LWB- 454 and patina 1971 Blazer - Rusty 1968 Crewcab project Last edited by Bagd72Chevy; 12-09-2018 at 09:44 PM. |
12-04-2018, 12:12 PM | #2 |
C10 Collector
Re: Crew Cab Build
Reserved #1
///Ryan 1972 Chevy C-10-Bagged, Blown LT1, 700r4, Suicide Doors 1967 GMC- SC & Cam'd 4.8, built 4l80, 3200 stall, posi, 4.10 1967 Chevy LWB- 454 and patina 1971 Blazer - Rusty 1968 Crewcab project |
12-04-2018, 12:13 PM | #3 |
C10 Collector
Re: Crew Cab Build
Reserved #2
12-04-2018, 12:15 PM | #4 |
C10 Collector
Re: Crew Cab Build
Reserved #3
12-04-2018, 02:50 PM | #5 |
Re: Crew Cab Build
I am along for the ride.
Nice work.
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
12-07-2018, 04:05 PM | #6 |
Re: Crew Cab Build
This is going to be a great build. Look forward to the updates.
12-07-2018, 11:16 PM | #7 |
SWB 4x4 Collector
Re: Crew Cab Build
As one who has dissected a burb roof during my build, the Burbs do have that a pillar reinforcement.
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
12-08-2018, 02:06 AM | #8 |
Re: Crew Cab Build
Looking good
12-09-2018, 03:16 PM | #9 |
Re: Crew Cab Build
Looks like a good start
12-09-2018, 09:43 PM | #10 | |
C10 Collector
Re: Crew Cab Build
12-14-2018, 12:55 AM | #11 |
Re: Crew Cab Build
Along for this build too
Wade |
12-14-2018, 01:31 AM | #12 | |
Re: Crew Cab Build
That will help you a lot.
12-17-2018, 05:29 PM | #13 |
C10 Collector
Re: Crew Cab Build
Yes sir! I already have 2 older lifts in the shop but it will be nice to have a super wide 12k now. The other 3 10k's are going to my buddy's. Just need to get the power ran and hooked up.
12-21-2018, 03:32 PM | #14 |
I'm trying....
Re: Crew Cab Build
Nice deconstruction and pics. Great reference. Subscribed. Looking forward to more. Thanks for taking the time.
1970 K20 Z62 https://67-72chevytrucks.com/vboard/...56#post9334756 1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
12-27-2018, 03:06 PM | #15 |
Re: Crew Cab Build
Nice work so far, hang in there..
