01-01-2019, 05:49 PM | #1 |
landarts
Door Panel renew
Bought these at the local pick-a-part a few years ago for $10 each. They were in good shape, each of them had an extra hole where the previous owner added an additional screw. Also one panel had a very small burn/melt flaw where someone probably drop a cigarette and burned it.
I scrubbed them both down with a 1/1 mixture of hot water and simple green and a hard bristle carpet brush. Wiped them down with grease and wax remover and they looked splotching from the chemical. So I did another round of Simple Green and hot water. After they dried they looked much better so I spray down the areas for repair with a coat of SEM plastic adhesion promoter let that flash and then a few coats of SEM texture spray. Before the texture was dry I blotted it with a wrinkled up piece of saran wrap to simulate the existing texture for the repair area which was only about 1/4 of inch square. Next after the texture dried I sprayed both panels with SEM adhesion promoter and let it flash. Followed by three coats of SEM color coat. I am very happy how they turned out and will be installing in the next couple of days. SEM products have it down to a science and make it look like new again. I am a big fan of there system. First picture is the before picture and second of he completed process.
Super Cheyenne aka the "Devil Cowboy" 71 K20 Idaho Edition 69 K10 from the Field 68 Second Chance Fix and Sale 72 GMC 3/4 ton 4x4 K2500 The "Fixrupr" build thread 72 Cheyenne 1/2 ton " FIXRUPR " - daily driver 67 C20 all original paint 71 K20 Custom 4x4 (Idaho Edition) 72 K20 GMC Super Custom 4x4 72 K20 Custom Deluxe 4x4 69 K10 Custom package 4x4 (69 K10 from the field) 72 K10 Custom 71 K10 Custom 72 K20 Custom Deluxe 4x4 72 K20 Crew Cab Project 71 GMC Jimmy CST 72 Blazer 70 Blazer |
01-01-2019, 06:44 PM | #2 |
Re: Door Panel renew
Good job they look like new .Wish i could actually get thouse style door panals but i have a 71. All whell steel panels are fine. I gess.
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original ) 94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless 07 gmc sierra classic rcsb 4.3 lt 5 speed w/t 04 chevy Silverado 1500 ext cab 5.3 4l60e. 81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green) |
01-01-2019, 07:39 PM | #3 |
Amazing. I would have thought they where new. Nice job.
There's something women like about a pick-up man 1967 c10 swb Stepside 2004 SSR 2013 Silverado swb |
01-01-2019, 07:59 PM | #4 |
They look good. Thanks for the post. I was wondering about those products and the different steps needed.
01-02-2019, 01:52 PM | #5 |
landarts
The pictures look a little like there is a gloss to it, I think the garage lighting did that. The black I used is more of a satin to match really well with factory items like my new black buddy bucket seat covers. When I put it next to them the sheen looks right.
01-02-2019, 07:48 PM | #6 | |
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
07-17-2022, 11:51 AM | #7 |
Junior Member
what color did you use ? Satin Black ?
07-17-2022, 03:19 PM | #8 |
landarts
SEM Satin Black 15243 was the color used.
07-18-2022, 10:47 AM | #9 |
Junior Member
thanks for replying, thats what i thought, just wanted to be sure
