03-29-2019, 04:26 PM | #1 |
My 72 K10 4x4
My dads Truck 72 K10 with 70 xxx original miles on it last time it was driving would have been in 85 helped my dad put an old 350 into it
I was aiming for a budget rebuilt engine for her We went through 8 blocks I had The one from the truck I got from carlsbad NM had 75 Thou wear on it. Out of 8 one was ok to rebore machine shop tanked and bore it out when I came to pick it up I asked did he flux the block first The Lifter valley cracked from front to back .... Started to piece together a new gm roller block eagle rotating assembly vortech head Comp cam roller 4x4 cam vortec performer intake and carb |
03-29-2019, 04:28 PM | #2 |
Re: My 72 K10 4x4
Scored a sweet present for my 72
I was given a factory tach for it |
05-04-2020, 03:49 AM | #3 |
Re: My 72 K10 4x4
My Brother was given this welder after the contractor blew it up under load
I went fixed a major gas leak burnt wiring and disabled the broken selection leads did some test welding with it with what I had in the yard my cables looking at getting a Lincoln 180 mig to go with this Miller for some reason decided to stop making a 180 mig option |
08-13-2020, 07:24 PM | #4 |
Re: My 72 K10 4x4
Made some progress on my truck Thanks to my cousins Steve and Warren installed my windshield for me today
I need to clean the glass and get the review mirror tab glued on I had a new rubber for another truck i used to have i used that and deleted the trim for now I will change it back to ss trim once i blast it apart to get painted Priority is make her drive |
08-14-2020, 08:50 PM | #5 |
6>8 Plugless........
Re: My 72 K10 4x4
Progress is progress! At least when the trucks set out in your neck of the woods they aren't all rotted out like around here.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
08-16-2020, 03:24 PM | #6 |
Re: My 72 K10 4x4
My truck from Arizona was very clean as well
I find its how much milage the truck has for how makes a big difference |
08-16-2020, 11:24 PM | #7 |
Re: My 72 K10 4x4
I am spliting my time up as well between taking breaks for my broken leg and gathering and salvaging parts for starting to build my 68 back up into a c10 she used to be
I have enough to put both on the road and plan to try have them running before snow flies |
08-19-2020, 01:29 PM | #8 |
Re: My 72 K10 4x4
Pulled a rebuilt engine from a truck was thinking of using it short term in the 72
I did not realize it was an two piece rear main seal engine my new engine is a 1 piece rear main block not wanting to buy 2 clutch for this truck My son and daughter helped clean up the engine and paint and re gasket it |
08-19-2020, 04:36 PM | #9 |
Re: My 72 K10 4x4
Well that's it for things sandblasted and using air tools
Dam 3000 dollar industrial electric motor starter breaker never closed properly now cooked my compressor motor it was supposed to protect it started the compressor fine I went to work sandblasting my brackets I ran out of air went back to see what the issue was .... |
08-25-2020, 03:27 AM | #10 |
Re: My 72 K10 4x4
Sorry to hear about your electrical problems. Wow, 3k Must have been an enclosure + installation and wiring. Replacing just the magnetic starter should only be a couple hundred dollars. Would definitely check breaker amperage and wire size if the motor in the compressor was cooked.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
08-25-2020, 11:45 AM | #11 |
Re: My 72 K10 4x4
I am an industrial electrician and was givin it by one of my employers when we closed the mine
Yes it is a complete industrial stand alone mag starter assembly with spring return hand off auto postions I have to adjust and locktite the handle And yes the breaker and overloads are sized according to the compressor |
05-18-2021, 05:31 PM | #12 |
Re: My 72 K10 4x4
I have not worked on it much lately still healing my busted leg
Did get some new to me wheels on it last fall and my son cleaned out the box for me We had planed to drag it into the shop over the winter but complications stopped that Now that its warming up and the truck is not buried under 3 feet of snow Decided last summer to wait and put in the new 350 into her rather then use the 350 my son and I pulled due to having to buy a second clutch pack new roller cam block is 1 piece rear main seal the block out of the 92 is a 2 piece rear main seal we will stick that in another truck at some point it was rebuilt a few years before that truck was parked |
