Old 04-29-2019, 09:37 PM   #1
CST10
CST10's Avatar
Replaced power booster and MC. Pedal soft now
Well ol Samson got a new brake booster (stock) and master cylinder. Stock 4 drum brake system. Bench bled till no bubbles. Installed and hooked up lines. Bled from the farthest to the closest ran about 2 quarts through the system until clear fluid at each point.
Brake pedal still seems soft and sinks further to the floor than before. Way softer than before and goes almost to the floor before it stops. Also brakes don’t lock up like they use too.
Old MC leaking out the back end seal and old booster leaking was the reason for replacement.
Checked booster for leakage, nope. Checked vacuum, at 18hg, nope. Checked all bleeder points, no leakage, nope.
Guess I’ll try to bleed the system again.........any ideas?
MyToys:
Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles.
Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop.
Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ.
Member of the Louisiana Classic Truck Club, LCTC
Member of the Louisiana C10 Club
Member of the Baton Rouge Drifters Car Club
CST10 is offline   Reply With Quote
Old 04-29-2019, 09:42 PM   #2
AussieinNC
Moderator
AussieinNC's Avatar
Re: Replaced power booster and MC. Pedal soft now
Is the bore diameter of the new master the same as the old?
Is the size of the power booster unit the same as old?
Is the pivot point the same as the old?
Are the brakes adjusted correctly?
Can you pump up the pedal?
Does the pedal drop when pumped up and then the engine is started?
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 04-29-2019, 10:20 PM   #3
External
External's Avatar
Subscribed
'72 Chevy Custom Deluxe Highlander. Med Olive/White 350/200 ps,pb and Air Conditioning!
External is offline   Reply With Quote
Old 04-30-2019, 07:40 AM   #4
enduroride
enduroride's Avatar
Neil, try that bleeder system that Stevens dad posted on the club website.
Wade
2016 Silverado2005 GMC Sierra
2002 Chevy Slverado Extra Cab (youngest sons)
2009 GMC Denali (oldest sons)
2015 Lexus 250i (wifes)
1972 Chevy C10 LWB, 5.3 / 4L60e swap "COLOR OF MONEY"
http://www.louisianaclassictruckclub.com
enduroride is offline   Reply With Quote
Old 05-02-2019, 11:01 PM   #5
CST10
CST10's Avatar
Yeah, I’m try that system out. Hopefully it’s just trapped air in the master. Had this issue quite a few years back one time. Took me two times bench bleeding it.
MyToys:
Old 05-02-2019, 11:03 PM   #6
CST10
CST10's Avatar
Yes it is.
No change
Yes
Yes
Yes, so the booster is good.
See above
MyToys:
Old 05-02-2019, 11:15 PM   #7
Mbeef61
Mbeef61's Avatar
Are the pushrod depths the same in both master cylinders? I know there is a deep and a shallow one. A deep one where there should be a shallow would make it so it doesn’t brake until the pedal is to the floor
Mbeef61 is offline   Reply With Quote
Old 05-02-2019, 11:26 PM   #8
CST10
CST10's Avatar
That is an excellent point. I will compare them tomorrow when I pull the new one back off to try a second d bench bleed. Still got the old one on the table.
Thanks. Had not even thought of this as a potential issue.
MyToys:
Old 05-03-2019, 01:13 AM   #9
Mbeef61
Mbeef61's Avatar
I think one is for power brakes and one is for manual but when at the parts counter there is so specification on it. Seems like it’s luck of the draw
Old 05-03-2019, 04:06 PM   #10
volksworld
i believe the manual is a one inch bore and the power is larger...i just dont remember if its 1 1/16 or 1 1/8
1970 short step c10 leaf spring 454
volksworld is offline   Reply With Quote
