Old 04-30-2019, 01:12 PM   #1
HeavyHauler
Does a 4/6 drop kit require C notching the frame on 68 C10
I would like to lower my 1968 Chevy C10 fleetside using a 4/6 drop kit but I am not sure if that would require C notching the frame in which I would not want to do. Anybody know if that is something that would need to be done in order to lower it that much?
HeavyHauler is offline   Reply With Quote
Old 04-30-2019, 02:40 PM   #2
67_C-30
I have a radical idea!
67_C-30's Avatar
Re: Does a 4/6 drop kit require C notching the frame on 68 C10
A lot of people have got by with 4/6” without c notching (myself included) but it’s really close. On my truck it required removing the bump stops and would bottom out in the rear if I hit a really big bump at speed. That was a rare occurrence, but it would happen. Most of the time it was fine.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 04-30-2019, 06:15 PM   #3
rjs53
I did an ECE 4/6 drop and wasn't even close to needing a C notch, but did it thinking I would before I got the suspension stuff.
2003 Dodge 2500
1969 C10
2014 Camaro SS/RS/1LE
rjs53 is offline   Reply With Quote
Old 04-30-2019, 06:24 PM   #4
rjs53
Give me a few and I'll get a picture of the distance between axle and frame so you can judge for yourself
2003 Dodge 2500
1969 C10
Old 05-01-2019, 08:43 PM   #5
rjs53
Ok so from the top of the axle to the bottom of the frame is 3”. Not a lot of room. ECE says nonotch needed, I’ll leave it up to you. With the Cnotch there is about 5.25 “ from top of axle to bump sto
2003 Dodge 2500
1969 C10
Old 05-01-2019, 08:44 PM   #6
rjs53
Whoops upside down
2003 Dodge 2500
1969 C10
Old 05-03-2019, 11:32 AM   #7
Vermillion67
Here is my 67 C10 swb with 4 inch CPP drop springs plus 2 inch drop blocks. I have about one inch to the bumps and three inches to the chassis and no notch. It will hit the bumps occasionally but mostly I do OK. (Not sure why my photo rotated).
Vermillion67 is offline   Reply With Quote
