Old 05-02-2019, 12:32 PM   #1
Baker72chevy
Spark controller
What does a spark controller do?
Baker72chevy is offline   Reply With Quote
Old 05-02-2019, 03:26 PM   #2
Minkota
Re: Spark controller
if you are referring to an Ignition Controller like the "MSD" type, then it has a much stronger spark which is needed in higher compression engines. they also allow for "Rev Limiter" and in some cases a "2-Step".
Minkota is offline   Reply With Quote
Old 05-03-2019, 08:46 AM   #3
rpmerf
rpmerf's Avatar
MSD stand for Multiple Spark Discharge. Under like 3000 RPM, it gives 2 sparks. Above 3000 it gives 1 big spark.
Agree with the previous post, they usually have a built in rev limiter, and you can sometimes (depending on the model) set up a staging rev limiter. When you hit a button, there will be a lower rev limiter, so you can launch at the perfect RPM every time.
There are other features, like start up spark retard. This is useful for engines with a lot of initial advance, it makes it easier to start. They can retard timing for things like boost or nitrous.
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is offline   Reply With Quote
Old 05-03-2019, 11:07 AM   #4
Baker72chevy
This
Old 05-03-2019, 11:22 AM   #5
rpmerf
rpmerf's Avatar
Retards timing in 3rd gear by blocking vacuum to the vacuum advance. There are several threads on it. Search TCS or trans controlled spark. Most people just remove it. It is connected to a solenoid on the pass side of the intake.
1997 GMC Suburban
Old 05-03-2019, 11:56 AM   #6
68 P.O.S.
Close, it stops the vac advance from working until the engine is at operating temp and the trans is in 3rd gear. Yes, people remove it because its an early, archaic attempt at emissions control and it no longer serves any good purpose.
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
