![]() Join Date: Nov 2006
Coil wire replacement question
Reciently i hired a supposeably mechanic to replace my th350 trans and the guy pinched my coil ign. Wire between block n trans. Well when i hit the key it went to ground,dead short,fried the coil to switch wire. I need to replace it but as i understand it its a resistor wire to cut voltage to coil. Guys i dont want to go hei ign. What route do i need to go in fixing this problem.
Regards n thanks bob
I BELIEVE IN JOHN 3:16 |
Re: Coil wire replacement question
I take it your "supposeably Mechanic" isn't taking responsibility for the damage?? Replacing the resistor wire is a simple process.. Remove the wire from the harness and install a replacement.. If you are unable to locate a source of new resistor wire, salvage one from a donor vehicle. All GM vehicles of that era employed a resistor wire in the ignition circuit. Another option is to install a ballast resistor in series with a "regular wire"..
Solder won't "stick" to the wire so you'll have to resort to very well installed crimp connectors.. Factory type terminals are available.. Check to be sure no other wires or components, including the ignition switch were damaged by the heat.. |
Who Changed This?
![]() Join Date: Jan 2013
Do you have a receipt for the work? It's on him to fix what he messes up. Otherwise, Rusty has your solution.
paid cash, I just wont use him anymore. thanks guys
If that piece of wire is still smashed between the engine and bellhousing, I would want it removed.
Its out.
![]() Join Date: Apr 2016
As a premium member, I have had good luck just posting the question does any of the many people who has replaced their wiring harness have their old harness laying around and wouldn't mind selling pieces of it. In my case I was looking for some plugs and I made a deal with somebody to send me some for a reasonable charge. The non-adhesive vinyl tape that the factory wrapped the wiring with is available from a variety of catalogs and from Amazon.
I,d love a resistor wire and the 1 from r terminal on starter to coil.
Post Whore
![]() Join Date: Feb 2016
I have some information on how to replace the pins in the firewall connector in my WBM thread below, (starting on post 388) if you are interested.
http://67-72chevytrucks.com/vboard/s...698377&page=16
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
