Old 05-19-2019, 10:17 PM   #1
Marty68
Please help identify engine.
I have searched and can not find my casting number listed. Was told it is a 283. I not know year or any details please help.solve the puzzle. Looks to have bellhousing changed with engine. Bellhousing # searched out to be 12 " truck. I hope to put a newer stuck behind it t5? Unsure as of yet.
Marty68 is offline   Reply With Quote
Old 05-19-2019, 10:23 PM   #2
Marty68
Re: Please help identify engine.
Here is bellhousing #
Old 05-19-2019, 10:57 PM   #3
Captainfab
60-66 Nut
The DE code comes up as either a 283 or a 307. Your casting number of 3849852 comes up as a '58-'66 283.
http://www.nastyz28.com/gm-chevy-cod...s-suffix-4.php
https://www.mortec.com/castnum.htm
Old 05-20-2019, 05:02 AM   #4
Marty68
Did a 307 ever have the cartridge filter? Will this bellhousing work with a t5?
Old 05-20-2019, 08:33 AM   #5
68Gold/white
307's started in 68. To my knowledge a 307 would not have a cartridge filter. I have seen a couple 307's, they had spin on filters.
68 was the first year for larger crank journals on all small blocks. 68 and up blocks no longer had the "breather" passage at rear of block, by the dist. hole, either.
Someone here will likely have info on the bell housing, that part of the question is waaay to new for me...
68Gold/white is offline   Reply With Quote
Old 05-20-2019, 09:08 AM   #6
geezer#99
geezer#99's Avatar
Might find a bit of info in here on T5 swapping.
http://67-72chevytrucks.com/vboard/s...d.php?t=313954
Old 05-20-2019, 06:04 PM   #7
Marty68
I was on a 4spd swap site they said that truck bellhousing will alow a 12" Clutch but should not be used with a "car" trans without a bushing? Adapter....
Researching option puting with 51. Have to finish just needs cab painted. All body work done just needs prime block prime sand paint.
Old 05-20-2019, 07:05 PM   #8
geezer#99
geezer#99's Avatar
What are you running for a rear end?
What ratio?
Old 05-20-2019, 09:27 PM   #9
Marty68
i just bought a 3.42 s10 4x4 rear
Old 05-20-2019, 09:41 PM   #10
geezer#99
geezer#99's Avatar
Fairly wide rearend.
With that ratio you likely won’t need an o/d tranny.
Old 05-20-2019, 10:30 PM   #11
Marty68
that gear is the most common in a blazer i think an overdrive would put you at 1800 rpm at 60 (283 may not have enough torque...) th350 would be 2400 rpm at 65 long term i want MII... just saw a local guy selling rebuilt th350 long or short shft. $375. would need floor shifter converter flex plate kick down cable and cross member.
still thinking
open to advice and sugestions.
th350 is stronger than t5
Old 05-20-2019, 10:39 PM   #12
geezer#99
geezer#99's Avatar
283 is happier at higher rpm.
Most motors are.
Around 2500 at cruise.
Good deal on a t350.
Likely all done would be same price as a t5 conversion.
283, 47-55, bellhousing, engine casting codes
