Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 06-26-2019, 09:00 AM   #1
Markuli
Markuli's Avatar
Added an AUX input to my radio the other day and it actually works!
Just figured I'd post this up for anyone who finds it useful.
I found a video online for a guy who wired in a very rudimentary AUX input to his corvair radio: https://youtu.be/AhktHMXoSbQ
As it turns out, our truck's AM radio is pretty much the same as this one. So if you follow his vid, and wire the positive lead (with a resistor) to the blue volume switch wire and the ground to the brown switch wire, you'll be able to play all the tunes you like. Be sure you wire in a MONO 3.5mm jack. I think you *might" be able to combine the two positives from a STEREO jack and make it work as well, not sure.
I opted to go the cheap route and just wire in a regular mono jack. I don't know what electrical magic happens when you plug in your MP3 player, as I figure both inputs must be going at this point... If I plug in my MP3 source while I'm on a station, I can still faintly hear the station before I play my music. I've found that if you tune the radio to static, your MP3 input is the most clear- sounding. Of course, you can absolve yourself of any concern and add a fancy switching 3.5mm jack to ensure your AM input circuit is broken once you plug in.
By wiring this cable in and wiring a pair of cheap Advance Auto speakers in series to bring my resistance up, I now have a decent mono setup that still fits under the dash. Don't bother with any songs that use a lot of bass, of course. Naturally, the songs from the age of mono speakers sound the best, but a quick test with a Dragonforce song proved pretty decent
Markuli is offline   Reply With Quote
Old 11-15-2019, 07:35 PM   #2
projectking
projectking's Avatar
Re: Added an AUX input to my radio the other day and it actually works!
I use a Bluetooth adapter and set the iPhone’s eq to bass canceling and it sounds good with all types of music!
68 GMC C3500 Longhorn DRW
67 Chevy C10 LWB
90 Mustang Gt
90 Mustang Notchback
projectking is offline   Reply With Quote
aux, mp3, radio, stock
