07-05-2019, 11:05 AM | #1 |
Carb Rebuild Yields Extra Parts!?!
My daughter and cleaned and rebuilt a 1972 c10 Quadrajet Carburetor. Things were going well until we found two issues, one of which we will order the second is where we are stumped.
1. Our carb is missing the Power Piston Spring, I'm ordering one today. 2. We found we ended with an extra part and can't find a diagram, pic, or anything related to this bonus part: Secondary Air Valve Cam (see stock pic below). While I know that being more efficient is important, I can't see having extra parts left over from a rebuild being a good thing. Can anyone provide a pic, or an idiot proof reference where this little guy should be located in my carburetor? Thank you in advance. Mike |
07-05-2019, 11:36 AM | #2 |
Re: Carb Rebuild Yields Extra Parts!?!
OK, on top of the carb, there is the area or housing where the choke flap resides...
Just to the rear of that, on top is the secondary air flap. That flap controls secondaryair into the secondaries... If you push down on the sec air flap, you will see the secondary fuel metering rods raise up, at the same time you push down on the flap. This little piece of plastic is what is raising the needles. It's on the sec flap shaft, right in the middle. |
07-05-2019, 11:37 AM | #3 |
Looks like the cam that goes on the secondary rod in the top plate to me.
68 beat me to it, what he said. |
07-05-2019, 12:10 PM | #4 | |
07-05-2019, 12:11 PM | #5 |
07-05-2019, 12:17 PM | #6 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
That is the Secondary Air Flap Cam. It locates inside the slot (between the two air flaps) on the Secondary Air Flap Shaft. Underneath the Secondary Metering Rod Holder shown as #9 in this diagram. http://www.carburetion.com/Quads/M4MC-E.htm Here's the kicker, most kits and diagrams don't show or come with that part. Although the link above does have them available, they do not show an installation procedure or diagram. They have a phone number though, call em up...
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
07-05-2019, 01:41 PM | #7 |
I've never had any issues with that part being/going bad. It can be a royal pain if it's worn down a little, or a lot, performance problems...
07-05-2019, 01:55 PM | #8 | |
Thanks for your help! |
07-05-2019, 02:54 PM | #9 |
Post Whore
The power piston spring Is what controls the part throttle enrichment. When at steady state cruising the engine vacuum is high pulling the piston and the metering rods down to the leanest position. When the throttle opens and vacuum drops the spring pushes the piston up and raises the rods richening the fuel mixture.
There are at least a dozen different springs that were used in Qjets and they all respond at a different vacuum level. When you call they should at the very least ask you what your manifold vacuum is at idle. If you were to know what the vacuum is at cruise that would help them get you the correct spring. Having no spring probably means you have had poor light throttle acceleration and maybe some lean misfiring and or pinging.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
07-05-2019, 03:41 PM | #10 |
Who Changed This?
You will need to pull the secondary air valve flaps off and pull the shaft out part way to get to where you can install that metering rod cam. Use a lot of car over by the secondary air valve return spring to avoid damaging it. You need to remove it to get the shaft out. This part broke on my truck, and I don't know where the parts went. It just about died whenever I floored the throttle, because it got lots of air and no fuel. I ordered a carb kit from Cliff Ruggles and asked that that cam be included.
07-06-2019, 08:49 PM | #11 | |
07-06-2019, 08:51 PM | #12 | |
07-06-2019, 10:40 PM | #13 | |
Who Changed This?
If you can't find it, it was probably cycled through your engine like mine must have been. In order to take it off during a rebuild, you'd have to do what I said earlier, with removing the secondary air valve flaps, etc.
07-06-2019, 11:30 PM | #14 | |
Thanks for your help on this and other parts I've came across and started. |
07-07-2019, 04:30 PM | #15 |
Post Whore
You are welcome sir.
07-07-2019, 08:04 PM | #16 |
Who Changed This?
ĄDe nada!
07-13-2019, 01:31 PM | #17 |
The parts came in and the carb now moves like I hoped it would. Thank you for your help one and all.
One item of note for any future folks who may need this, the Secondary Air Flap Cam goes with the large side facing towards the center of the carb, not with the large side resting against the piece the Secondary Metering Rod Holder connects with. It looks like it is made for the large side, but then the carb won't open when it's supposed to. We learned that little detail too! |
Tags |
carberator, carburetor |
