08-23-2019, 09:38 AM | #1 |
EFI Crew Check In - Experience
I've been researching and strongly considering going with Holley Sniper EFI and was just wanting to get peoples experience. Share with all of the world here
Year: Make and Model: Type of EFI: (Holley, FiTech, Etc) Engine: How long have you had it: Experience: Let's hear what you have and how you feel about it? |
08-23-2019, 10:32 AM | #2 |
Re: EFI Crew Check In - Experience
i had so much fun with my holley sniper i had a bumper sticker made up for it . my specific thread http://67-72chevytrucks.com/vboard/s...ghlight=sniper
and not to be rude but in the last few months in this section there has been efi ? just like yours already with lots of info posted . sniper = http://67-72chevytrucks.com/vboard/s...archid=6467863 fitech = http://67-72chevytrucks.com/vboard/s...archid=6467865 edelbrock = http://67-72chevytrucks.com/vboard/s...archid=6467867 hard to search just edelbrock and get efi only so i just did there newest setup . i went edelbrock pro flo 4 my 2nd go round and could not be happier in the end .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
08-23-2019, 10:40 AM | #3 | |
Before starting this thread I search specifically for all EFI Threads to ensure I wasn't duplicating as you can see below: |
08-23-2019, 02:58 PM | #4 |
cool . no problem . glad my info helped on the sniper .
good luck in what ever unit you pick .
08-23-2019, 05:01 PM | #5 |
Post Whore
get a LS and be done with it..
08-23-2019, 05:38 PM | #6 |
not that i dont love my L31 and edlbrock pro flo 4 but wish i had just done the ls swap also . but the main reason i did the L31 was i was limited on time and needed a bolt in setup and few wires for the pro flo 4 and she was running .
08-24-2019, 11:53 AM | #7 |
In my '72 Suburban I have a 880 block 350, steel crank, powdered metal rods and flat top pistons,comp efi roller cam, aluminum heads topped off with a holley stealth ram manifold. The controller I am using is a microsquirt
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
08-25-2019, 11:52 AM | #8 |
MSD Atomic full kit sitting on top of BBC. Rear tank, MSD kit fuel pump mounted external to tank, return type fuel system. Been running in this configuration for 2 years/4000 miles. Only trouble has been some idle quality due to bad IAC module, which was resolved once the IAC was replaced. I also accidentally destroyed the hand-held That cost 250 to replace. Hth, -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
08-26-2019, 01:26 PM | #9 |
i am running a FiTech 600hp easy street, it was an easy install. But some hidden programming had me baffled at the start...it has an RPM based fuel pump on setting, factory setting was 2000 rpm...it would squirt, start and then die.
once i set that, it is/can be based off of A/F ratio and seems to be working very well. |
08-26-2019, 01:37 PM | #10 |
Thanks everyone for chiming in.
08-26-2019, 04:23 PM | #11 | |
Make and Model: GMC C1500 Type of EFI: Holley Sniper Engine: 454 How long have you had it: 2 summers Experience: No complaints. Does what it's supposed to, always has right from the start. The truck has an endless supply of other problems, but the EFI has been trouble free.
2007 GMC 2500 CCSB LBZ 1991 GMC 1500 RCSB 350 1981 GMC Street Coupe RCSB 454 |
10-26-2019, 12:27 PM | #12 |
[QUOTE=Android04;8580641]I've been researching and strongly considering going with Holley Sniper EFI and was just wanting to get peoples experience. Share with all of the world here
Year: 1969 Make and Model: Chevy C10 Type of EFI: Holley Sniper Engine: very mild 350 How long have you had it: 6 months Experience: Ignition problems drove us crazy at first, but after sorting that out it's been positive overall - we've had to replace the IAC, but that was our fault (long story). The truck starts and runs better than we can ever remember, and the mileage is up from 10-11 to 11-14. We're still fine tuning the cold start and acceleration enrichment tables. Things I've learned: 1. ANY weakness in the engine, especially the ignition, will be exposed, and magnified. Get ready to replace spark plugs, and make damn sure your exhaust has ZERO leaks ahead of the WBO2 sensor. 2. Wiring procedures are the single most important part of the install. Good clean power, lots of solid grounds, eliminating RFI/EMI, etc will save you a TON of problems. 3. "Self-Tuning" is an overpromise. But that's not limited to the Sniper, I don't care what system you use. For example YOU have to figure out the Target A/F Ratios at idle, cruise, WOT, and points in between that YOUR engine likes FIRST, then the system "learns" what it takes to get to them. Like any computer, it's garbage-in-garbage-out. Some systems may take more variables into account and have better initial setup tunes, and some engines (like a stock sbc) may have better info available regarding the Target settings, and some engines may run better/worse with less tinkering, but (IMHO) if you want your engine to run as best it can, you're going to have to climb the rather steep EFI learning curve, dig into the programming, and tweak it yourself. With the Holley Sniper, their manuals are ok, but not great. But their online forums have a ton of good info available, I hear that their tech phone line is pretty good, and they seem to stand behind their products as least as well as anybody else. I've used their forums a LOT, and have learned a lot of helpful stuff - but then I'm kind of an info-geek that likes to dig deep into whatever project I'm working on at the time, so I don't mind. 4. Would I do it again? YES. We had some teething issues, but no more than with any other new technology.
My Chevy Truck Project Build Thread '62 Ranchero - 200 I6, 3-on-the-tree, power nothing. '71 LeSabre - 455 Stage 1, power everything. |
Tags |
efi, eldebrock, fitech, holley, sniper |
