Old 09-22-2019, 03:17 PM   #1
VentureRick
VentureRick's Avatar
PO171 and PO174
I have a 2002 1500HD with a 6.0 with 133000 miles on it, a couple of days ago it started running really bad but no check engine light came on, I was able to drive it back home and hooked the scanner up and it through these 2 codes, I cleaned the MAS air flow sensor and replaced the air filter and it ran fine so I cleared the codes and drove it a few miles then it developed a slight hesitation off of idle, I have checked for vacuum leaks and have not found any, checked the fuel pressure and its only running 25 to 30 pounds with vacuum line unhooked at the regulator, I changed the regulator and it still reads the same, what should the fuel pressure be and is there a certain way your supposed to check it, thanks in advance,
Rick
69 SWB Project
95 Suburban Daily Driver
47 Flxible Motor Home 427 GMC 4spd Allison
71 C-10 LWB 307/350 (parted out)
64 SWB Custom Cab 283 powerglide (sold)
2000 Yamaha Venture
VentureRick is offline   Reply With Quote
Old 09-22-2019, 05:28 PM   #2
Re: PO171 and PO174
Have you check for intake manifold leaks? I have also heard an exhaust leak before the first O2 sensor(s) can cause that lean condition issue.
Old 09-22-2019, 07:12 PM   #3
AussieinNC
Moderator
AussieinNC's Avatar
Re: PO171 and PO174
Key on, engine not running, fuel pressure should be 55-60 lbs
Turn key off and fuel pressure should not drop by more than 5lbs...
25 to 30 running is way too low....its a wonder it runs at all...
Sounds like a bad fuel [pump or bad fuel pressure sensor....my money is on the fuel pump...
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 09-27-2019, 08:47 PM   #4
VentureRick
Re: PO171 and PO174
Ok I found out the fuel pressure tester I was using wasn't reading right, my pressure is 55 not running, I did change the fuel filter and it has been running great, thanks for the help.
Rick
69 SWB Project
2000 Yamaha Venture
Old 10-26-2019, 09:38 PM   #5
truckdude239
truckdude239's Avatar
Re: PO171 and PO174
Mine did same thing turned out to be intake gaskets
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
