Old 11-27-2019, 02:55 PM   #1
Reno
Reno's Avatar
Cummins Swap 1968 Suburban - wish list
I've followed posts on the site so i thought I would reach out for advice.
I'm gathering parts for a Suburban with Cummins build
Heres what I have so far
1972 Suburban K10 rolling frame
1968 Suburban rust free body
1992 D250 Cummins Pickup with auto
Rob Bonney Frame box kit & motor mounts
With Black Friday here and vendors offering deals what would you buy?
I'm older and don't want too much lift. This will be a daily driver - I live in Colorado.
I believe the Front & Rear differentials (Dana 60 & 70) from my donor truck will work. Strong running 5.9 but it has the VE Rotary pump so looking for the required parts to upgrade to P Pump. The auto trans is slipping as it was a snow plow truck.
thanks in advance.
Reno is offline   Reply With Quote
Old 12-01-2019, 10:28 PM   #2
Ziegelsteinfaust
Re: Cummins Swap 1968 Suburban - wish list
I am dreaming of my own Cummins swap someday, but a VE pump is a good set up unless your shooting for big time power.
This is off memory here, and stuff i halve read. How true I do not know.
The VE pump is good to roughly 500 hp with the right parts.
Supposedly a bit easier to start the a P-pump, and slightly better mpg.
Also quite a bit cheaper since no one wants them if you need spares compared to a P-pump.
Ziegelsteinfaust is online now   Reply With Quote
Old 12-05-2019, 08:13 PM   #3
projectking
projectking's Avatar
I run a VE in mine, it will get you to 400’s not so sure about 500...better off finding a p pump engine vs buying the swap items. it’s a great running truck and a blast to drive, do it!
68 GMC C3500 Longhorn DRW
67 Chevy C10 LWB
90 Mustang Gt
90 Mustang Notchback
projectking is offline   Reply With Quote
Old 12-05-2019, 10:30 PM   #4
goldenburb
goldenburb's Avatar
Good luck on your quest.
If you do a build thread make sure you post good info & details. 2years and I’m still collecting parts and struggling on info for my 67 4x4 cc Cummins build.
70 c10 2wd crashed Suburban
67 c10 2wd sb truck
67 c10 4wd lb truck
goldenburb is offline   Reply With Quote
