Help with the bottom side of Hood
What coating or cover would you put on the underside of your hood
Re: Help with the bottom side of Hood
How much are you planning on driving your truck? I simply painted the underside the same as the entire truck, no problem. Go to GOOGLE and type in painting underside of hood and click on Eastwood's article.
![]() 1940 Ford Dlx Coupe 1969 Mach1 |
body color paint works for most of us
don't use undercoating it will be to heavy for the springs
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
Thanks guys
I cleaned the bottom of the hood with the wire wheel on my angle grinder (there was surface rust on the bottom side of the hood). Then brushed on POR 15. Then my painter painted the bottom side of the hood body color.
Wade
53 Chevy 3100, SBC 355, 700R4, S10 frame, Ford 8.8 rear with 4.11 gears, front disc & rear drum brakes |
spi black epoxy.
As several others painted body color. If I was going for a plainer look I'd paint it inner fender black.
Mine has 120 louvers in the hood so any kind of coating would make a mess. I had a hood one time that someone had undercoated and it was heavy. I think I ended up hauling it for scrap as it was too much trouble to clean the mess off it. The only possible viable reason for putting any other coating on the bottom side of the hood is if you didn't want engine noise getting out what there is of it. Not too many AD truck folks are very worried about that.
