Old 01-01-2020, 05:16 PM   #1
ibinyth
Body panel differences between 67 and 68-72
I understand that the 67 bedsides have different mounting holes, what about the front fenders on a 67, besides not having side markers are the mounting holes the same? In other words can I run them on my 70 c10 with the original 70 hood? I'd like to run 67 fenders and bedsides.
ibinyth is offline   Reply With Quote
Old 01-01-2020, 08:48 PM   #2
projectking
projectking's Avatar
Re: Body panel differences between 67 and 68-72
Need ‘67/8 hood or modify the later one
68 GMC C3500 Longhorn DRW
67 Chevy C10 LWB
90 Mustang Gt
90 Mustang Notchback
projectking is offline   Reply With Quote
Old 01-02-2020, 05:49 AM   #3
my kids toy
You would need a whole front clip to run 67 fenders, even the rad core support, even head light change, ( everything from the fire wall forward needs to be changed ) to run 67/68 on a 69-72
my kids toy is offline   Reply With Quote
Old 01-02-2020, 06:34 AM   #4
67/68 fenders and hood are longer than 69-72. 67/68 grille is sheet metal that integrates with the fenders and hood. 67/68 headlights sit wider than 69-72, so core support is different from 69-72.
'67 bedsides have different mounting holes?
Old 01-02-2020, 01:51 PM   #5
ibinyth
Alright, I appreciate the replys guys.
Old 01-03-2020, 05:14 AM   #6
GMCPaul
1967 bed sides mounting holes are Exactly the same as 1968-72 bed side mounting holes. The only difference between 1967 & 1968-72 is there are No side marker light openings on the 1967 bed sides, otherwise it is exactly the same.
In regards to the front clip everyone's correct you will need to replace the entire front clip to use 67 front fenders and have them just bolt up without modifications required. Now you could modify the leading edge of the front fender on the 1967 fenders so that the 69-70 grille will fit over the front edge of the 67 fenders but it would be far easier just to cut out the opening for side marker lights on your 69-72 front fenders and then weld the opening shut to delete the side markers. Far easier than trying to modifying the leading edge of the 67 fender or grafting the leading edge of a 69-72 fender onto a 1967 fender to make it work in order to get the 69-70 grille to fit over it like it does on the 69-72 Chevy.
Paul Jr @ GMCPauls
GMCPaul is offline   Reply With Quote
Old 01-03-2020, 05:16 AM   #7
ibinyth
Yeah, I'll just be filling in the side marker openings.
Old 01-05-2020, 01:56 AM   #8
Ben IV
Some good information on this thread. One thing I didn't see mentioned is that GMC's used the same fenders from 68-72.
70 GMC custom short bed conversion
69 GMC panel truck
Ben IV is offline   Reply With Quote
Old 01-06-2020, 10:52 AM   #9
landarts
landarts
Body mount rubber supports for 67-68 are different than the 69-72 for the front clip.
Super Cheyenne aka the "Devil Cowboy"
71 K20 Idaho Edition
69 K10 from the Field
68 Second Chance
Fix and Sale 72 GMC 3/4 ton 4x4 K2500
The "Fixrupr" build thread
72 Cheyenne 1/2 ton " FIXRUPR " - daily driver
67 C20 all original paint
71 K20 Custom 4x4 (Idaho Edition)
72 K20 GMC Super Custom 4x4
72 K20 Custom Deluxe 4x4
69 K10 Custom package 4x4 (69 K10 from the field)
72 K10 Custom
71 K10 Custom
72 K20 Crew Cab Project
71 GMC Jimmy CST
72 Blazer
70 Blazer
landarts is offline   Reply With Quote
Old 01-06-2020, 03:00 PM   #10
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
And the same core support as well for those years.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 01-06-2020, 03:48 PM   #11
68Gold/white
What fenders did 67 GMC's use??? I guess you are considering the 67's because of the lack of clearance lights...
68Gold/white is offline   Reply With Quote
Old 01-07-2020, 03:23 PM   #12
'67 GMC used the same as Chevy '67s, except for fender emblem holes.
'68-'72 GMC used the same as Chevy '68s, except for fender emblem holes.
'69-'72 Chevy fenders are Chevy-only.
GMC followed the same shorter hood design change as Chevy in '69. The Chevy fenders changed to allow the grille surround to sit "into" the fenders. The 3pc GMC grille surround changed to sit "over" the fenders and fill back to the hood over the grille.
bedsides, fenders
