02-04-2020, 08:52 PM | #1 |
divorced np205 transfer case, pinion and u joint angles
My truck is a 64 k20. I have removed the eaton rear axle and swapped a 14 bolt, I have removed the front closed knuckle solid axle dana 44 for a open knuckle dana 44 and replaced the rockwell t221 for a divorced np205 from a international pickup mated to a 472 cad with turbo 400. Current angles are 8 deg pinion up , trans output 3 deg down, t case output 3 deg down.I also have installed springs and shackle flip on rear from 79 k20 and 6 inch lift springs from 72 k20. Other than the pinon at 8 deg up do I need to change any other angles, and if just the pinon should I drop it lower to compensate for axle wrap? Have the eaton axle sitting on frame to compensate for the weight of the bed that is buried in 3 feet of snow.
02-04-2020, 09:19 PM | #2 |
Post Whore
Re: divorced np205 transfer case, pinion and u joint angles
set your rear diff at 3deg up...with those spring packs you wont have much wrap
02-04-2020, 10:46 PM | #3 |
Thanks for the reply, I failed to mention that the rear springs are 56 inch from a 79 heavy half but the axle and front hangers are from the k20. Will that change your answer?
02-04-2020, 11:43 PM | #4 |
Post Whore
naw...id still go 3deg up on rear axle
02-05-2020, 09:20 AM | #5 |
Pretty sure the t-case is level or tilted back slightly. I built an 89 GMC that I SAS'd using a Dodge 205, sat level, even with 14" of lift it didn't vibrate on the highway. The 40" boggers on the other hand lol....the rear should be pointed at the output of the t-case.
02-05-2020, 12:45 PM | #6 |
02-06-2020, 01:45 AM | #7 | |
^^^ This. As long as pinion to t case output are parallel and t case to trans are parallel each shaft should cancel itself out.
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
02-06-2020, 07:48 PM | #8 |
fyi divorced t-case all have 32 spline in/out for the yokes so if you dont like the yokes you have there super common to get replacements for .
and for the old cool factor and easy shifting i would twin stick that 205 . be real easy on the divorced case . then get a boot for a jeep with the old twin stick for a completed floor look .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
02-06-2020, 11:53 PM | #9 |
The twin stick mod is on my back burner list. As far as the yokes it has all 1310 joint size. When I took out the t221 the rear output yoke was a 1350 style so I swapped slip yoke to match.I want to go to with 1350 style to replace it . Just wondering if I should do all 3 and if the chineseum ones hold up.
02-07-2020, 12:01 AM | #10 |
01-29-2022, 01:56 PM | #11 |
Guess I could search, but are 1410 yokes available too? I would want 1410 for the input and rear output. 1310 is fine for the front axle shaft.
Cable -K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt -Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608 |
01-29-2022, 02:07 PM | #12 |
Offroaddesign.com has some. But a search will find some too.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
01-29-2022, 09:35 PM | #13 |
i think you can get 1480 also .
01-30-2022, 02:34 AM | #14 |
U-joint working angles and calculating them somewhat confused me a while back. Then I found someone that explained it in a way I understood. Attached a chicken scratch drawing of the way it make sense to me.
You can see I indicated the differential angle as down. Does not make sense right? pinion is pointing up. If you start at the t-case or transmission draw a line through all the components. You can see the line is angled down at all positions. If you start at the differential, it is angled up at all positions. You can do it either way. U-joint working angles are determined by adding or subtracting the two angles at the joint. Down/Down or Up/Up you subtract the two Up/Down or Down/Up you add the two A CV or cardan joint has two u-joints in it that cancel each other out so the working angle at u-joint on other end of shaft should be at 0 degrees. Probably +or - 1 degree as no working angle is not good as well. Also should add to avoid vibration an attempt to get working angles at both ends of shaft within 1-2 degrees is best. Maybe this info not asked for but hope it helps someone.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 Last edited by Richard; 01-30-2022 at 03:06 AM. |
02-03-2022, 09:38 AM | #15 |
Just went through all this with angles myself. It's more than just the 2 being paralled - Watch the Tom Woods video about it all!
https://67-72chevytrucks.com/vboard/...d.php?t=829600
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" '06 3500 Duramax ...tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
02-03-2022, 12:48 PM | #16 |
raylube, Do you have pics of the case mounted in your frame? I would like to see what you did. I am going to do the same thing with an internatioal case and mount, just looking for ideas.
63 k20 with cummins 4bt, owned sence 1982 |
02-04-2022, 09:48 PM | #17 |
Used international factory L brackets and new poly mounts from international ihc parts, thevrear cab mount rivets are almost where i put mine but didnt want to modify Jack shaft length.
02-04-2022, 09:59 PM | #18 |
Some more
02-06-2022, 02:05 AM | #19 |
Great job on the divorced mount! Would have liked to go that way myself, but the SWB kept me from doing it.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
02-08-2022, 04:26 PM | #20 |
Looks good! Thanks for the pics. I thought it would work that way but have not pulled my t221 transfer case for a mockup yet.
02-08-2022, 08:34 PM | #21 |
Post Whore
truck looks great Ray!!!!!!!!
02-09-2022, 05:47 PM | #22 |
That's my dream truck..
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
02-10-2022, 04:07 AM | #23 |
Thanks. Here's truck in action. https://youtu.be/voju5s7jvGs
02-10-2022, 11:30 AM | #24 | |
Proprietor of Dale's Corner
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
02-11-2022, 07:48 PM | #25 |
Ray,
How are those front springs mounted? The stock front brackets and rear shackles? Modifications? I'm thinking of trying out those front springs, but in a 4 inch lift. Thanks
1966 K20 flatbed build thread - http://www.67-72chevytrucks.com/vboa...d.php?t=768827 62 C20 build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=703583 |
