Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 GMT400 Chevy & GMC Pickups Message Board > projects and builds 88-98
Old 02-15-2020, 12:15 PM   #1
diveplane
Nv3500 seals
i have a leaking transmission its coming from the top of the stick shift dripping down tranny casing, is this the culprit needs replaced here never done this before , this easy to do guys?
https://www.amazon.com/Chevy-Nv3500-.../dp/B0112E6M0E
diveplane is offline   Reply With Quote
Old 02-15-2020, 12:17 PM   #2
diveplane
Re: Nv3500 seals
also a rubber gasket i think i will replace around shift column
https://www.allstategear.com/Jeep-NV...shoppingengine
Old 03-12-2020, 03:09 PM   #3
Second Series
Second Series's Avatar
Re: Nv3500 seals
I had a similar situation with my 5LM60, leaking from the top. Actually, the problem was my knuckles hitting the dash. The bolts that hold the shifter housing were loose, the threads in the aluminum transmission case were stripped. I finally mustered enough courage and put in a heli-coil type part. That second seal that you posted, I should have replaced that, it was chewed up. I put gasket goo on it instead.
'47 Panel to '88 K2500 Frame Swap
Mechanical Speedometer Drive Solution
1947.2 1 ton Chevy Panel
1955.2 Chevy 6700 Bus/RV
1990 Chevy K1500
Second Series is offline   Reply With Quote
