Old 04-06-2020, 05:35 PM   #1
8man
Firewall replace??
I need to replace the firewall and have no idea how I'm going to hold it in place to plug weld it.
Does anyone have any tips and tricks for doing this?
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 04-06-2020, 06:13 PM   #2
crossfire84
crossfire84's Avatar
Re: Firewall replace??
Use Cleco clips or sheet metal screws.
LIL ERV the 50-3600
396 BBC stroked to 415 cid
Richmond 6spd over drive
C4 rear
Porter built a arms
Never give the Devil a ride,because he'll want to Drive!
crossfire84 is offline   Reply With Quote
Old 04-06-2020, 07:29 PM   #3
mongocanfly
Post Whore
mongocanfly's Avatar
If your doing a overlapped seam , then Clecos X2....all you'll have is 1/8 holes where they were..start in the center and work out to the ends
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 04-06-2020, 08:55 PM   #4
mr48chev
mr48chev's Avatar
I learned to use clecos when I worked at Boeing in 1966 and they are great for holding overlapping panels. We would use the pre drilled rivet holes for them on aircraft panels.
They are spring loaded so you can't get them hot. I got a kit off
Ebay a year or two ago to use on overlapping panels.
My ongoing truck projects:
Old 04-11-2020, 12:55 AM   #5
LOW A D
I agree clecos the best way but you can also use self tapping screws to hold a panel in place where clamps don't work. In this pic you can see the clecos holding my firewall in place
My build- 51 Chevrolet
LOW A D is offline   Reply With Quote
Old 04-11-2020, 08:08 AM   #6
8man
Thanks guys. I will try them.
8man-aka Robert
Old 04-11-2020, 08:19 AM   #7
whitedog76
Great looking firewall, I need more details on it.
whitedog76 is offline   Reply With Quote
Old 04-11-2020, 09:09 AM   #8
whitedog76
I love the arched look of the AD firewalls.
I want to move my engine back slightly , But I know I'll have some intake clearance issues.
Old 04-11-2020, 10:59 AM   #9
LOW A D
Thanks, You can see how I built it if you look at my build
Old 04-11-2020, 03:43 PM   #10
dsraven
I have heard of guys using a steel wheel barrow tub for an engine set back in the firewall. already formed to look like it was supposed to be there for the classic year.
https://www.bing.com/images/search?v...jaxhist=0&vt=0
Old 04-12-2020, 12:49 AM   #11
whitedog76
I've seen the wheelbarrow firewall before. I actually picked up a Radio Flyer wagon with the same thought process. Since I did my MII install, everything changed, so I need to go up and back. LOW AD's firewall is exactly what I need. Back to the drawing board, I guess.
Old 04-12-2020, 04:06 PM   #12
mr48chev
mr48chev's Avatar
My buddy used a wheelbarrow in his Model A roadster and it worked pretty good. Used to be you could find a new metal garden wheelbarrow for about 20 bucks this time of year new but most are plastic now.
LS Fab makes some nice bead rolled firewalls For AD trucks but don't show any recesses. https://lsfab.ca/product-category/4754/ One would have to ask about the size of the opening around the engine though.
Old 04-12-2020, 07:27 PM   #13
e015475
e015475's Avatar
Firewall for a 4" setback- made on a HF bead roller
Initial fitting with lots of clecos
From the inside of the cab-
e015475 is offline   Reply With Quote
Old 04-13-2020, 03:37 AM   #14
MiraclePieCo
MiraclePieCo's Avatar
I used wide-jaw vice grips and those big triangular welding magnets.
1951 Chevy Panel Truck
MiraclePieCo is offline   Reply With Quote
