Old 04-16-2020, 12:45 PM   #1
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Rear Tank - Difference in Ride?
Maybe the Suspension forum is an odd place to ask this question, but for those who moved your tank out of the cab to the rear, did you notice a change in the way your truck handled?
66 C20 Service Truck:
Old 04-16-2020, 08:00 PM   #2
PGSigns
PGSigns's Avatar
Re: Rear Tank - Difference in Ride?
I have the boyd welding tank in my 66 along with a host of other stuff done and the ride is good. Can't say the tank alone made it better but it does make the weight split better. Good springs, shocks. a lower stance and a long track bar all work to improve the handling.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 04-17-2020, 10:05 AM   #3
Custom 68
Custom 68's Avatar
Its probably hard to get a definitive answer as it will be somewhat subjective but moving the weight rearward and lower certainly makes sense.
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 04-17-2020, 10:23 AM   #4
LostMy65
LostMy65's Avatar
I know, kind of a hard thing to confirm. I'm thinking it should help.
Should also help with rear traction.
Old 04-21-2020, 04:08 PM   #5
Ziegelsteinfaust
Moving the weight rearward also can mess with ride height. A kid i did work for put a Blazer tank there, and a full tank was almost a inch lower then empty.
Other then that it seemed to help traction a fair bit too. Although we put a 4.3 in there for him. Since he rode 3" off the ground at the frame he could get in trouble quick even with the 6 gun.
Ziegelsteinfaust is offline   Reply With Quote
Old 04-21-2020, 04:26 PM   #6
68racer
Yeah baby!
68racer's Avatar
Yes, it felt better, lower center of gravity so less roll and better weight distribution.
11.37 @116
68racer is offline   Reply With Quote
Old 04-23-2020, 01:56 PM   #7
SCOTI
SCOTI's Avatar
Dave
Not only is it subjective, each truck will be different. Different spring rates, shocks, wheel base, tire sidewall height, & tank volume would all impact the ride.
If one wants to know for 'their' truck, put a similar amount of weight @ the end of the bed & burn a tank of gas for the best answer.
The weight can be 50# bags of mulch or whatever. Buy it @ Wally-World, keep the receipt, & return it on your way back from the testing. Estimate your required weight @ 7lbs per gallon of capacity (6.x per gal of fuel; the extra weight would be tank materials weight).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-23-2020, 03:26 PM   #8
LostMy65
LostMy65's Avatar
I'd agree it's subjective.
But my question was for those whose variables hadn't changed.
They moved the tank to the rear, what did they notice.
Good idea on throwing 50#'s in the rear of the bed.
Old 04-23-2020, 04:24 PM   #9
SCOTI
SCOTI's Avatar
My point was also maybe their set-up was already better or worse than yours. The results would only reflect what they had & how it was impacted.
Adding 3-4qty 50# bags is easy enough for someone to test their exact set-up to know what they think.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-23-2020, 07:04 PM   #10
LostMy65
LostMy65's Avatar
Yeah, I already have a tank I plan on putting in the rear. So my question was really general curiosity. And it's a good chance having the tank in the rear won't be enough to notice anyway. I'm just sitting around the house thinking of threads to start. 😷
Old 04-23-2020, 07:33 PM   #11
SCOTI
SCOTI's Avatar
No problem. Others will see the info so it might help their decision process.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-14-2020, 01:36 AM   #12
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Interesting question and one one in my head. My truck is stock height but have an ECE 23 Gallon stainless steel rear tank ( bought in 2003 for my other truck and never used it ) and one of their hidden hitches to mount as well and a Hellwig Rear Sway Bar to mount too. Future plans are to do a 2 1/2 Front Spindle Drop and a 4 inch Rear Spring drop with adjustable Trac-Bar and repositioned shocks which will level the truck out somewhat without the extra weigh of my rear accessories. Thanks for the idea of loading up the weigh in the box to see how far she drops with the extra weight cause I sure dont want the front of the truck higher than the rear when the gas tank is full. I'll take the sway bar and hitch to work and weigh them on the industrial scale, and I think the gas tank is sixty pounds empty but will take it too. I love how there is always ideas to pick up and things to learn when scrolling the different threads and posts.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 08-14-2020, 09:48 AM   #13
SCOTI
SCOTI's Avatar
That's why we're here. When people share ideas, good things can happen.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-10-2020, 03:08 PM   #14
Bronik290
When I moved the tank from the cab to under the bed of my 67 C10 I didn't really notice a difference in handling. The biggest difference was that the ride was less bouncy with a full tank of gas. I have the 17 gallon tank and prefer to drive it with the tank as full as possible.
Bronik290 is offline   Reply With Quote
Old 12-12-2020, 02:21 AM   #15
LostMy65
LostMy65's Avatar
Thanks, that was my thinking.
Old 01-06-2021, 10:30 PM   #16
Damien
Damien's Avatar
Good idea Scoti on the extra weight for testing.
I've driven a few trucks with coilovers on the rear all right about 1,600 lbs for rear axle weights. The trucks with rear mounted tanks ride very well with 200 lb./in. springs. If the fuel tank is mounted ahead of the axle like the '73 & newer GM trucks I prefer a little lighter 175 lb./in. springs. The added leverage on the suspension makes a noticeable difference.
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
Old 01-12-2021, 12:23 AM   #17
ChevyRacefan
ChevyRacefan's Avatar
Adding weight pass the rear axle, in a vehicle that is prone to oversteer, can make it worse , The fuel slapping the tank side, helps wanting to turn(oversteer) the rear off the truck
ChevyRacefan is offline   Reply With Quote
Old 04-12-2021, 02:56 PM   #18
Bad70sbchevy
Bad70sbchevy's Avatar
I moved mine to the rear (in cab to Camaro gas tan mounted behind rear axle) and I didn't notice much of a difference dailying it. Did notice it improved rear traction when accelerating (as one would expect).
1970 Chevrolet C-10 w/355sbc
2010 Silverado Daily Driver
1971 Mercedes 280sl project car
Bad70sbchevy is offline   Reply With Quote
Old 07-15-2021, 02:58 AM   #19
Already Gone
Here we are a year later and had my rear tank installed in May. At the same time I had a Hellwig 1 1/8 inch rear sway bar installed too. Cant say if its from the tank being in the back now or because of the rear sway bar but my truck is much more stable and rides better now that it did before. Can't wait to get my 2 1/2 dropped spindles and 4 inch drop coils installed on the truck as I'm sure that'll make the truck handle even better..
Old 07-15-2021, 08:04 AM   #20
67C10Step
67C10Step's Avatar
I am rolling down this path but won't really know about ride improvement since I didn't drive it before I changed everything. It has a 2-1/2 and 4 drop and just put the Boyd tank in last weekend. Starting the plumbing this weekend I hope.
I decided to move mine to the rear for safety and I had a 70 model stepside as a teenager and it always seemed light in the rear. Thinking the extra weight behind the axle should help. We shall see.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2020 Toyota CH-R
2020 Acura MDX
67C10Step is offline   Reply With Quote
Old 07-15-2021, 09:13 AM   #21
blazer2007
I don,t worry about the truck being lower with a full tank, I can,t afford a full tank LOL. I have the large blazer tank
blazer2007 is offline   Reply With Quote
Old 07-15-2021, 11:35 AM   #22
LostMy65
LostMy65's Avatar
And your pic also answers my other question in another thread. Exhaust routing:
Old 07-16-2021, 09:11 AM   #23
blazer2007
I did notice on my Blazer with a full tank and on certain sections of a hiway it would start to rock alittle like a boat in the water and my short box truck of the same year didn,t do that. Could be suspension related or not but just something I thought when I saw this thread on the subject
