Anyone know how to lubricate the speedometer bushing? Older Chevy's have a cup plug on the side of the cast housing. Under the plug is a felt wick that holds the oil. My 1971 C20 doesn't seem to have this feature. Is it serviceable?
1971 C20 Custom Deluxe, HT383, 4L80E, 3.73 Locker, 4 Wheel Discs |
![]() Join Date: Jul 2015
Re: Speedometer Lubrication?
Hmmm, have not delved into that one yet. I would bet Lock Doc or the T-Bone will be speaking out to ya soon!
This doesn't directly answer your question but I like this stuff for lubing cables...
I 'had' an old bottle of stuff called "Kable Ease". I used it on heater control cables, speedo cables, etc. I really like this stuff. The last time I used it, the plastic container cracked and leaked all out ![]() Anyway, I just googled and apparently it's still available... https://www.amazon.com/Ags-Kable-Eas.../dp/B000ZO0EA2
'68 C20 Utility 396 4sp (BuildThread: http://67-72chevytrucks.com/vboard/s...d.php?t=806904 ) '68 C10 50th |
my 4spd ch465 and np205 have splash oiling. Speedo correction box is sealed. For the cable you pull the guts out and shoot some white lithium grease inside it then reinstall the wire.
I disconnect at speedo and squirt graphite cable lube in. You can give a shot of air to help it get lower better faster, then add a bit more. That works for me. A more thorough way to go would be remove, clean, lube, install. PITA, yes, but one and done on this, more than likely second lubing in 50 years
#6 | ||
When I worked in the shop and had a customer complaining about a jittery or noisy speedo cable we would pull it from behind the speedometer, clean it, then lube it with a graphite based lube that won't freeze up in the winter.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
That I a very good point
#8 | |
Unfortunately, you guys took my thread about the speedometer bushing (at the speedometer head) and turned it into how to grease a drive cable. So, anyone know how to service the speedo head?
#9 | |
I didn't realize there is a bushing on the speedo head. I have never done anything to them other than screw the cable in or unclip it. Looking forward to learning something here.
![]() Join Date: Feb 2014
Vaseline Has worked for me for 60 years
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent |
Vaseline? I'm asking how to service the speedometer bushing. Wow, just wow....
#13 |
Carpe manana
![]() ![]() Join Date: Dec 2010
This....
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#14 |
I have wondered about this myself. I did use some white lithium sparingly on the gears for the odometer. Vasoline is a petroleum product and it does make sense. The bushing on mine was dry as well and I used sewing machine oil 0 weight but it wont last long. I will add some vasoline I need to pull it apart again to add a trans cooler gauge anyway.
#15 |
https://imgur.com/UyAeoYs Here is a link to a pic of a 1967 - 1972, C10 / C20 speedometer head (hope the link works, I'm old and still angry about photobucket). How did anyone manage to apply vaseline to the bushing?
1971 C20 Custom Deluxe, HT383, 4L80E, 3.73 Locker, 4 Wheel Discs Last edited by bry593; 05-06-2020 at 01:11 PM. |
#16 |
![]() Join Date: Mar 2012
Bry593 From one Okie to another where are you from?
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks ![]() |
#17 |
Currently in Broken Arrow, just east of Tulsa.
Tags |
cable, lubrication, oil, speedometer |
