![]() Join Date: Jul 2001
'05 Tahoe 5.3 Oil Change
Well after trading off our '99 Tahoe for the '05 in Dec. last year coming up on the first oil change for it according to the 'oil life' percentage. Has full synthetic oil in it and plan to stay with that, Quaker State 5W30 and a WIX 51042 filter. Reading thru the owner's manual says need to change within 600 miles of the "Change Oil" message coming on. Okay, fine, where does that message show? The book does not mention that. Is it on the digital speedometer readout or does it show on the dash elsewhere? Owner manuals sure get thicker every year with all the bells and whistles now days.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
Re: '05 Tahoe 5.3 Oil Change
It will show up on the gauge cluster. Here’s how to reset it:
https://m.youtube.com/watch?v=YzDCGS_kQoo
Customization is what you want it to look like -- not what other people think it should look like |
#3 | |
Moderator
![]() Join Date: Jun 2017
The "Change Engine Oil Soon" message should appear on the display panel where the mileage displays....maybe its faulty...
Perform an Engine Oil Change reset as follows: Engine Off Turn Key on but do not start engine Press Accelerator pedal hard to the floor 6 times in quick succession Start Engine Message should display "Engine Oil Life Reset".... If it doesnt, the Oil Life monitoring system may have been disabled or is faulty. Let us know how you go... ![]() ![]() ![]()
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox ![]() ![]() ![]() |
#5 | |
On our Suburban, also running synthetic, it comes on about every 8k miles, but message does not come on & stay on. It will come on when first crank up & then on & off occassionally when it's time.
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" '06 3500 Duramax ...tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
Hasn't popped up yet, will keep watching. Our odometer read out is not near that bright. Have the dash light switch turned up bright but can't hardly see it during the day unless sitting in the garage? Is that an easy fix or .....? Seems nothing is easy or not costly to fix on these new fangled contraptions, LOL.
Probably have bad solder joints. Google 1999-2006 Silverado cluster repair and you’ll find plenty of tutorials on how to resolder. Done the fix plenty of times for dim or no displays. Common fail items for these NBS clusters.
Moderator
![]() Join Date: Oct 2008
Several groups of SMT resistors develop cracked solder joints.
There's a right way and a wrong way to open the cluster and care has to be taken to not botch it. A $10 WalMart soldering iron is not the tool to use on this kind of work. Look at some of Jeffscortlx videos on Youtube. https://www.youtube.com/channel/UCzJ...89YYt4GBxNaJfQ
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
Well guess the "Change Engine Oil" popped up on the odometer window yesterday coming home from a quick turn around 300 mile round trip out of state. Came on several times and then reverted back to the odometer mileage so guess it is working correctly. Just REALLY dim, hard to see. Looked at a few u-tube videos and get the feeling not something this ol man wants to tackle. Not the best with a soldering iron and when I don't feel comfortable doing a repair I let those with more experience step in. Not always cheap but then neither is a botched repair that needs fixing. Will look into repair locally that can do such. The dim reading is irritating for sure.
![]() Join Date: Feb 2000
I know these guys aren't local but we've used them for cluster rebuilds and the service is great and quick turn around. Highly reccommended
https://www.gmgaugerepair.com/
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
Changed the oil and filter today on the '05. Boy, 5/W30 oil flows quick when it is warm, LOL. Luckily had the pan in place but dropped that hot pan bolt in the oil and had to get the magnet to fish it out. Really went a bit easier than our '99 Tahoe as the filter on the '05 sits vertically and not angled like the '99 did. Had to make a quick run to the parts house tho and get a 6th quart of oil. Had bought a 5 qt jug like always did on the '99, that wasn't enough, quart shy. Got the oil life percentage set back to 100% with no problem. Still need to change the trans filter and fuel filter.
Have not looked into the dim cluster light fix yet but that is on the list also.
![]() ![]() Join Date: Jul 2002
I don't remember for sure, but I believe the fuel filter is in the tank on that era of Tahoe's/trucks and gets changed when you change the pump.
#13 |
Never thought about that but your right. I Googled '05 Tahoe fuel filter replacement and Google said it is no longer a serviceable item. Part of the fuel pump assembly in the tank. Not at all sure about that being a good design engineering process but guess time will tell?
#14 |
Moderator
There's a strainer in the tank. The frame mounted fuel filter went away prior to 2005.
