06-10-2020, 06:28 PM | #1 |
Searching for L E D headlight Hack?
There was a thread on the 67-72 build forum that I have tried
many different search words for. And I cannot find it again. So I decided to post a Question About what the member done. Has anyone removed the tabs on a sealed beam headlight, and Then installed the small Led pigtail lights. What I am looking to do is, Put 4 little Led's in a mower that I seldom use the lights but I want them to work if I need them. Here's pics of the lights. Thanks in advance for your help. .
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
06-10-2020, 07:12 PM | #2 |
Post Whore
Re: Searching for L E D headlight Hack?
could you not just splice the led pigtail into your existing harness? or use blade connectors on the led pigtail and plug them into the existing plug?
06-10-2020, 08:56 PM | #3 |
I am trying to use these sealed beams in pics.
and install 4 small LED bulbs where the terminals are. The seal beams are melting the plastic on the hood. .
06-10-2020, 10:21 PM | #4 |
Post Whore
I think I understand ..maybe...your wanting to remove the filaments from the sealed beam and stick led inside the sealed beam bulbs?
06-10-2020, 10:32 PM | #5 | |
Something like in the picture below is what the member used. .
06-10-2020, 10:40 PM | #6 |
Post Whore
I gotcha now...not sure how youd do that ,I searched and saw a video where they put the bulb in a oven and separated the 2 halves but that's about it..
how bright would they be with 4 leds in them? me..id just replace the whole glass bulb with some led bulbs..
06-10-2020, 11:10 PM | #7 | |
Yeah I seen that video of separating the two halves That would cause a Lot of issues with the (better Half) if I put these in the oven I will probably go with the Led (fog light type) about that size. I just thought it would be cool to keep the sealed beam. I don't need much light /as I will not use it after dark much. I just want something so there is no blank space. .
06-11-2020, 02:12 PM | #8 |
What size sealed beam is that? If you search they may make an entire LED that replaces that and fits where the old one did. I run them in my S10, and lots of people use the 7" ones in Jeeps.
Edit: Looks like 4.5" tractor type??? Check this out https://www.superbrightleds.com/more...SABEgKH6vD_BwE Last edited by Bigdually; 06-11-2020 at 02:20 PM. |
06-11-2020, 05:32 PM | #9 | |
That is a better way to do this, Thanks for the link. I will order some of those install and be lit up Thanks again. .
06-11-2020, 06:14 PM | #10 | |
Glad I could help. |
06-13-2020, 02:41 PM | #11 |
Score
Found these at a Garage Sale today for $1 each. .
06-13-2020, 02:46 PM | #12 |
Nice! We need after install pics
