06-27-2020, 10:09 PM | #1 |
01 6.0 Broke oil dipstick tube
Well today just wasnt my day. Finally got my old crack right exhaust manifold off. But not before i broke the oil dipstick tube. And one of the quick disconnects for my heater hose.
Got another manifold back on. Fixed the quick disconnect. Noticed the tube broke flush with the block. So i pull the starter. Which ends up breaking also. So now theres 3 things broke. Finsihed pulling the starter to get in there to try using an ease out to get the tube out. Well not luck there. The tube is stuck in there. Not sure what other options i have before i either drop the feont diff and the oil pan. Or get really pissed and just pull the motor. Anyone have any ideas before i go to extremes to just get a small peice of tube out of the block? |
06-28-2020, 03:09 AM | #2 |
Re: 01 6.0 Broke oil dipstick tube
Have you tried using an easy out? They’re normally for broken bolts and screws, but since the tube already has a hole, the easy out may work.
Customization is what you want it to look like -- not what other people think it should look like |
06-28-2020, 08:05 AM | #3 |
Moderator
Thread a tap into it and pull it out?
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
06-29-2020, 09:21 PM | #4 |
Ive used an ease out. I used a tap. The is rusted in place. I used a lag bolt to give that a try also. With no luck.
But now i have more issues. The smaller part of the tube broke off under the portion that is stuck to the block. So now i get to drop the front diff. To drop the oil pan to take out the portion that broke and dropped into the pan. This truck has giving me nothing but problems. Im close to the end with this motor. Almost tempted to drop my 5.3 into it. Atleast i know i didnt have any issues with that motor. Only reason i parked it was due to a bad frame. |
07-01-2020, 12:01 PM | #5 |
Moderator
The 5.3 is noticeably less HP and torque.
It's a lot more work to swap the engine than fix the broken dipstick tube. Is the 6.0 giving you problems other than the manifolds and the dipstick?
08-08-2020, 02:34 PM | #6 |
Sorry for the delay on responding.
Ended up going back to work and have had very little time to work on the truck. To answer your question. I was having a bad miss after i drove the truck and got it up to operating temp. Since my last post. I have installed a new starter. Replaced the intake gaskets. Valley and intake. Replaced the valve cover gaskets. Every gasket was wore out and leaking or just pretty my bad. I have to replace the plugs again due to fouling them out when i went to start it. But thats minor. I ended up getting the stuck peice of tubing loose. But it ended up dropping into the pan as well. Ive talked with several folks who have had the same issue. And was told to just let it be. It wont hurt anything being in the pan. I do plan on doing an oil change and maye seeing if anything comes out. If not. No worries i guess. But the truck is back together. And running. Just missing due to plugs. So new plugs and start driving it again. Next issue to fix will be the oil pump soon. |
08-12-2020, 12:27 PM | #7 |
Just seeing this post, ran into the same issue on my '02 Yukon XL 6.0L a few years ago. I ended up using a lag bolt threaded into the broken dipstick tube and clamped a vice grip near the bolt head. Then used a long punch and hammer to tap on the vice grip to get the tube out. It took a few different tries but finally got it.
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
08-12-2020, 03:47 PM | #8 |
6>8 Plugless........
I had a 5.3 in a tahoe I had to unbolt the engine mounts, remove the fan and anything that wouldn't let the engine not raise up, drop the pan, and drive the rest of the dipstick through the block. There wasn't anything to grab onto above the block and nothing would grab it inside like a lag bolt etc.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
