Old 08-06-2020, 12:36 AM   #1
@19Chevy66
@19Chevy66's Avatar
Points to HEI problems
I have currently took out my points and added an HEI distributor. Ever since I've done that the truck will burn up my starter. I've gone through three starters. Do I have to disable the ignition pulse amplifier for my AGI to work? Has anybody else had this kind of problem? Thank you in advance.
@19Chevy66 is offline   Reply With Quote
Old 08-06-2020, 09:53 AM   #2
cwcarpenter98
cwcarpenter98's Avatar
Re: Points to HEI problems
Do you still have 3 wires going to your starter? You should only have 2 with an HEI. Power and trigger wire
Also, would you like me to move this thread to the electrical forum section?
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 08-07-2020, 10:36 AM   #3
PGSigns
PGSigns's Avatar
First how did you wire it and did you bypass the resister wire from the old setup. Next going through starters with an ignition change is a timing issue in most cases.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 03-21-2021, 12:21 PM   #4
@19Chevy66
@19Chevy66's Avatar
I have removed the resister wire and ran a switch power to the distributor.
Old 03-23-2021, 12:42 PM   #5
urmyboyblue
Does the switched power wire stay hot during cranking? Some 12 volt sources lose 12 V during cranking.
urmyboyblue is offline   Reply With Quote
Old 03-23-2021, 12:53 PM   #6
@19Chevy66
@19Chevy66's Avatar
That is the problem it does not turn over at all. I believe I have multiple issues. I got frustrated and put it away a couple months ago. Just pulled it out and started tinkering again and now I'm having problems with the horn relay. So many issues I don't know where to start.
Old 03-25-2021, 11:30 AM   #7
Chevy Fleetside
Chevy Fleetside's Avatar
It is safe to hook the HEI to the pink wire from your ignition switch.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
hei, pain in the ass, points, starters
