Old 09-18-2020, 11:06 AM   #1
pat english
pat english's Avatar
Glass question
Do suburban and crew cab use the same door glass?
I just got a 82 crew cab with all the glass broke out.i guess some punk threw rocks at it...
pat english is offline   Reply With Quote
Old 09-18-2020, 09:05 PM   #2
SilverMiner
SilverMiner's Avatar
Re: Glass question
Nobody else has responded yet, so I'll jump in and suggest that YES the doors are identical and therefore the glass should be as well. I say this because GM were frugal (some may say cheap) and wouldn't bother to design a unique door just for one specialized series of trucks. If they could re-use something, they always did. The only difference I'm aware of is the glass in the 73-80 years is supposedly thicker than 81 and on.
Also, if you look through the aftermarket parts catalogs the crew cab is almost always lumped in with the suburban. The rear door seals are the same as for both rigs, just as one example. I can't find a specific example for windows, but I'd be shocked if they were different. I just can't see the general spending that kind of money.
Honestly, that's one of the reasons I'm a GM fellow. I come from a GM family and my uncles used to say the parts manager at the Ford Dealer was paid better than the GM parts guy because Ford woke up every morning and had "a better idea" and constantly used different parts when the previous ones probably worked fine.
1980 K10 Suburban Silverado, original 350 w/Qjet swapped to 406sb, TH350C swapped to TH400/205
SilverMiner is offline   Reply With Quote
Old 09-21-2020, 10:53 PM   #3
pat english
Re: Glass question
Thanks for the reply.im also a fan of the compatibility of GM parts. (Plus I think they look good)
I scored some glass for my project over the weekend.im still needing the driver side front door glass if anyone has one locally.
