09-21-2020, 11:43 AM | #1 |
pinion angle is this right ?
Merged your two posts.
09-21-2020, 12:08 PM | #2 |
Re: pinion angle is this right ?
Forgot to mention is 454/450 auto setup
09-22-2020, 10:34 AM | #3 |
Oops ,should have put this in engine drivetrain section
09-22-2020, 08:18 PM | #4 |
pinion angle ,will this work
Getting spring pads welded on a Ford 9 inch for my 78 2 wheel dr. Blazer with a AOL bag set up. Current angles at ride height now are 5 -tranny 3.5 Dr.shaft 1 at pinion, all down. This has worked for over 15 years. I know this wrong but at the time when I flipped the rearend we just welded on new pads sorta even with the old pads. Now I sorts understand the pinion angles, so If I get the new pads on the 9 in. welded at 5 down and have 5 still at the tranny, will I still have 3.5 at the driveshaft. If so, this should work giving me a working angle of 1.5 at both ends. I do have room to shim the tranny. Is a454/450 hp with T. 350
09-24-2020, 09:05 AM | #5 |
anyone ?
09-24-2020, 11:21 AM | #6 |
pics???
09-24-2020, 01:33 PM | #7 |
Post Whore
You def dont want 5deg down on pinion angle...
like kw...some pics might help..
09-24-2020, 04:05 PM | #8 |
Not an expert on this but from what I learned chasing a vibration problem I once had is you want the angle at one end to cancel out the angle at the other end. So if the trans tailshaft is angled down 3 degrees you want the pinion on the rear to angle up 3 degrees. If you drew a line following the angle out the tailshaft and one out the differential following the pinion angle they should run parallel and never touch.
09-24-2020, 04:57 PM | #9 | |
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
09-24-2020, 09:06 PM | #10 |
So pinion should be up 5 degrees. Pics would not help. I don,t have lift
09-24-2020, 09:10 PM | #11 |
Post Whore
Correct..pinion up, trans down...but I would personally shoot for trans down angle 3deg..pinion up angle 3deg..
That's how I do mine when starting from scratch.. 3 and 3 Since your on bags I assume your riding low..you also want to avoid no ujoint angle..
09-25-2020, 08:58 AM | #12 |
Thanks, I was getting mixed up on how some people talk about slope when doing your math on operating angles
