Old 09-22-2020, 10:06 PM   #1
kipps
1990-1991 oil pressure switch?
I'm using a '90-'91 Suburban/Blazer gauge cluster on my build. I was intending to use the classic metal canister-type oil sensor, but I see that RockAuto is listing this black plastic sensor instead, for these last couple years of Suburban/Blazers.
RockAuto sells two styles; a long one and a short one. The short one is listed for use with a light, and the long one(pictured) is intended for use with a gauge. I like this style of sensor better because, with the right pigtail, I can clip the wire in place, instead of relying on a friction fit like the old style.
Are there any drawbacks to using this style of sensor? Do they have any longevity problems, etc? Do they definitely interface correctly with the 90-91 cluster?
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
