Old 09-25-2020, 02:18 PM   #1
flashed
74 Suburban Rear Window ????
How do I trouble shoot rear window not going down ? Does the round key usually fit the back door ? New to subs but would like the window to open . ClueLess in a Burb.
flashed is offline   Reply With Quote
Old 09-27-2020, 05:54 PM   #2
SilverMiner
SilverMiner's Avatar
Re: 74 Suburban Rear Window ????
The round key should operate the power rear window. HOWEVER, after 46+ years it's possible either the door locks have been changed or at the least the tailgate replaced without changing the lock.
There are a number of threads within this forum discussing steps to take to deal with a tailgate window stuck in the up position. It is not an uncommon problem and the search function will direct you to solutions you can accomplish yourself.
1980 K10 Suburban Silverado, original 350 w/Qjet swapped to 406sb, TH350C swapped to TH400/205
SilverMiner is offline   Reply With Quote
Old 09-27-2020, 10:41 PM   #3
flashed
I actually did a search before I started this thread , but thanks anyway . I will get it figured out on my own eventually .
