Old 09-29-2020, 01:49 PM   #1
pwdcougar
pwdcougar's Avatar
Supporting Suburban body
It’s time to reconnect the frame and body of the Suburban. The body is now on an rotisserie. The plan is to leave the back half of the Suburban on the rotisserie and support the front using the cab roof support at the doors. I was thinking of making two supporting towers of concrete blocks or 6X6 on either side by the front door openings. Heavy duty screw type (old house jacks) jack stands on top. Then a 2X12 laid flat across the cab under the top of the door opening.
Not sure my description makes sense. I can draw something up to make it more clear.
Any thoughts or ideas?
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
Old 09-29-2020, 06:08 PM   #2
Average Joe
Average Joe's Avatar
Re: Supporting Suburban body
That sounds stouter than a brick Schmidt house!
Seriously, Your work and planning, like many others on this site, is second to none. I have no doubt this is any less!
1967 C10 Suburban 454/TH400/3.07's
An Average Joe and His 'Burb:
http://67-72chevytrucks.com/vboard/s...d.php?t=775843
Average Joe is offline   Reply With Quote
Old 09-29-2020, 09:34 PM   #3
pwdcougar
pwdcougar's Avatar
Thanks Joe
My question really is if supporting the front of the body by the roof is a good idea.
Paul
Old 09-30-2020, 07:02 AM   #4
richard2717
Equal opportunity joke ofender
richard2717's Avatar
I have seen them picked up this way before. I would be a little concerned if the 2x12 was turned that way without a little extra support though to keep it from bowing
Members I have met.
Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb
https://paypal.me/6772GMtruckparts
Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type.
richard2717 is offline   Reply With Quote
Old 09-30-2020, 07:55 AM   #5
pwdcougar
pwdcougar's Avatar
Thanks Richard. That’s the info I needed. I’m planning on attaching 2x6 underneath to make a C channel. It wasn’t within my drawing capabilities at 9:30 pm. The 2x12 was planned to spread out the weight.
Paul
Old 09-30-2020, 09:27 AM   #6
polishspy
I used an engine hoist connected to the front lower eye location and a pipe through the rear marker lights to put mine back on the frame. Ill look for a pic.
polishspy is offline   Reply With Quote
Old 09-30-2020, 10:36 AM   #7
pwdcougar
pwdcougar's Avatar
Attachment 2052067
Thanks! I hadn’t thought of going from the side
