Old 10-13-2020, 05:38 PM   #1
kipps
hubcap question
Does anyone have a good chronicle of what hubcaps came stock on the squarebody trucks? I've seen an earlier and a later style of dogdish, but I don't know where the split was, or if there were more styles than that.
I've found a excellent thread on this site for 60-66 hubcaps, but I haven't found anything for the 73-87 hubcaps.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
Old 10-15-2020, 01:47 AM   #2
ShortHaul
ShortHaul's Avatar
Re: hubcap question
Here's a general breakdown. 4x4's would have a hole in the front cap instead of the center bowtie section.
For reference 1/2 ton caps measure 10.5" diameter and 3/4 ton caps are 11.75"
1969-1972
1973-75 (these are 3/4 ton) Same as 69-72 but with Ochre colored bowtie
73-75 3/4 ton GMC
In 1976 they went to the next style, the flatter caps. Not 100% sure when they quit putting hubcaps on, perhaps all the way up till 89...
That's more or less it in terms of dog dish caps. There were a few different full wheel covers seen on later suburbans and trucks, as well as ralley wheel center caps... But as far as dog dishes go... that's it.
"Sweet Pea" 1975 Cheyenne 20
http://67-72chevytrucks.com/vboard/s...00#post8477900
"Bourbon" 1975 Suburban ScottsdaleSOLD
https://67-72chevytrucks.com/vboard/...49#post8769049
”Otis” 1970 C10 SWB -SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=762766
”Chebby” 1962 Impala LS/TKO-500
http://www.pro-touring.com/threads/1...2-Impala-Build
ShortHaul is offline   Reply With Quote
Old 10-15-2020, 06:01 AM   #3
kipps
Re: hubcap question
Thanks, that's perfect!
One thing I have noticed on the "spoke" style dogdish, is the 5-spoke caps fit the 15" 1/2-ton wheels, and the 6-spoke caps fit the 16" wheels on the heavier trucks. I don't know if this same thing applies to the 1973-1975 caps or not.
Old 10-15-2020, 09:47 AM   #4
SCOTI
SCOTI's Avatar
Re: hubcap question
Definitely correct for the later caps. 5-spoke = smaller OD for 1/2 ton wheels/caps; 6-spoke = larger OD for 3/4 or 1-ton.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-18-2020, 10:09 AM   #5
factorystock
factorystock's Avatar
Re: hubcap question
73-75 3/4 ton GMC
Yes, all true, however, the base model pickups continued to use the white painted '73-'75 style as standard equipment thru the '78 model year. In '79 to '87, all models came with the flatter caps
factorystock is offline   Reply With Quote
Old 10-18-2020, 11:33 AM   #6
jocko
jocko's Avatar
Re: hubcap question
One nuance about the early 73-75 3/4-1 ton PO3 caps is that there were concave (innie) and convex (outie) varieties of the yellow bow tie center. 67-72 PO3s for 3/4-1 ton were all convex outies. Convex 73-75 PO3s seem to be fairly uncommon, most that I’ve seen were concave. (and note all 1/2 ton PO3 caps are concave innies).
