Old 10-17-2020, 09:57 PM   #1
56 3100
56 3100's Avatar
55-59 camaro clip with bigblock pics
want to see engine bay pics of truck with bigblock thanks. want to get an idea of firewall spacing i know you need enough room for removing valve covers etc.
https://ibb.co/vZwFd7t
496 video link
https://www.facebook.com/danny.andre...3881846060307/
56 3100 is offline   Reply With Quote
Old 10-18-2020, 03:22 PM   #2
Rickysnickers
Re: 55-59 camaro clip with bigblock pics
Here's a thread you might like to look at.
http://67-72chevytrucks.com/vboard/s...d.php?t=663322
Old 10-18-2020, 06:14 PM   #3
56 3100
56 3100's Avatar
having a scroll through now.
Old 10-19-2020, 09:29 AM   #4
heartattack
I have a 56 sitting on a 78 c10 chassis with a BBC in it. I have spent a year mocking up this engine. I have a automatic with the shift on the column. I have not modified the firewall. I did change the steering column to a RV steering column that is very similar to the van column.
As far as engine bay room between the firewall and the radiator support, it is tight. I have a 67 chevelle 4 row radiator mocked up and I will have to run a short water pump setup. I will be running a electric fan since there is only 3.5" between the water pump and the radiator with a short water pump. The long water pump measures 1 5/8 between the radiator on the water pump.
This is only in mock up stage right now, but I am just before blowing it a part to clean up and paint everything under the hood and assemble it for the last time.
If you would like pics just let me know and I will take a few before I pull it apart.
heartattack is offline   Reply With Quote
Old 10-19-2020, 09:35 AM   #5
Stepside Jim
Build thread with a big block also.
http://67-72chevytrucks.com/vboard/s...d.php?t=541132
My 57 Chevy truck build.http://67-72chevytrucks.com/vboard/s...d.php?t=541132
Stepside Jim is offline   Reply With Quote
Old 10-19-2020, 10:37 AM   #6
56 3100
56 3100's Avatar
thanks everyone i am struggling as to put engine up higher headers wise.jim do you have some more pics of your bigblock install ? are you using headers? gonna scroll through you build.i think headers are too low?
Old 10-19-2020, 11:41 AM   #7
geezer#99
geezer#99's Avatar
How low are you gonna go?
I built a 56 many moons ago but kept it stock height. Used an 80 gmc front frame that was grafted in place just in front of the body mounts.
Built it with a sbc and turbo 350.
Have you finalized your wheelbase?
You might gain an inch of room if needed.
Old 10-19-2020, 12:00 PM   #8
56 3100
56 3100's Avatar
Thumbs up Re: 55-59 camaro clip with bigblock pics
hi geezer wheelbase finalized. stepside jims pics helps a lot.probably raise engine up some. different input from various members always welcome
Old 10-19-2020, 12:12 PM   #9
geezer#99
geezer#99's Avatar
I upped my wheelbase an inch.
Nice thing is that deep engine bay.
Can’t tell by your pics but is your Camaro clip front or rear steer?
Front steer gives more room for bigger diameter headers.
I think front steer started about 1975.
My truck eventually got an 8-71 blown 427 in it. It’s in Smithers BC now.
Seeing your truck makes me wanna build another.
Old 10-19-2020, 12:14 PM   #10
56 3100
56 3100's Avatar
front steer. going in garage now loaded lots of pics lol
Old 10-19-2020, 01:33 PM   #11
BBPanel
I'm running the shorter valve covers so I have more room than you will. The headers are above the oil pan line. Starter fit OK but I had #8 tube moved out just to minimize heat. Plenty of clearance for motor mounts and steering shaft. I am running a remote oil filter - a shorty filter would have worked but oil changes would be a mess.
Size:  55.9 KBName:  20201019_120620.jpg
Size:  49.6 KBName:  20201019_120737.jpg
BBPanel is offline   Reply With Quote
Old 10-19-2020, 02:03 PM   #12
56 3100
56 3100's Avatar
thanks bbpanel . those the sanderson headers?
Old 10-19-2020, 02:04 PM   #13
Stepside Jim
Good afternoon, yes I did raise the motor mounts.
I used Patriot shorty headers for the exact reason you are having issues. I wanted to be able to determine the ground to exhaust clearance.
I didn't touch or alter the firewall.
I did use a two fan electric fan set-up the short water pump hub fits between the electric fan motors.
Feel free to ask more questions and enjoy the build pictures.
Old 10-19-2020, 02:12 PM   #14
BBPanel
Yes they are Sanderson C5 - for '32 up cars. The C6 is for '55 Chevy pickup - when I talked to them (back in 2001) they said the two are essentially identical but the C5 has more ground clearance.
Old 10-20-2020, 11:07 AM   #15
heartattack
Attachment 2055964Attachment 2055965
Attachment 2055967Attachment 2055968
Who's p/s and alternator brackets are you using? You appear to be running the short water pump. I like the look of your p/s and alternator setup over the traditional BBC short water pump setup.
Old 10-20-2020, 01:15 PM   #16
BBPanel
Its a long water pump. I started with a Alan Grove mid-mount alt bracket, flipped the alt up and used lower hole for a/c - then made the other brackets. The power steering pump bracket is Alan Grove also (I'm pretty sure - couldn't find the receipts and its been over 10 years) but I added the idler pulley because I didn't have a good way to tighten outer belt - and I don't like the belts hanging down (a/c belt also - plus concerned about not enough belt wrap on compressor pulley).
Old 10-20-2020, 10:56 PM   #17
Black_Sheep
Black_Sheep's Avatar
'75 Nova sub but I think it's the same as a Camaro
Black_Sheep is offline   Reply With Quote
Old 10-21-2020, 03:03 PM   #18
mr48chev
mr48chev's Avatar
I'm thinking the hangs down further on "truck" headers is somewhat universal. The set for the small block I had in my 71 hung down far further than they needed to and while great on a stock 3/4 ton two wheel drive would never work on a lowered half ton.
My ongoing truck projects:
Old 10-21-2020, 06:58 PM   #19
56 3100
56 3100's Avatar
mr 48 will raise engine up a bit. blacksheep your sooth firewall looks nice .
