10-18-2020, 09:21 PM | #1 |
camber
66 short bed with 72 crossmember can't get enough camber, got any suggestions
10-18-2020, 09:47 PM | #2 |
Re: camber
Remove shims?
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
10-21-2020, 10:30 PM | #3 |
Re: camber
What number are you trying to achieve?
10-22-2020, 08:26 AM | #4 |
Re: camber
Are you trying to get more positive or negative camber
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent |
10-22-2020, 08:55 AM | #5 |
Re: camber
less
10-22-2020, 09:25 AM | #6 |
Re: camber
You can have less positive or negative!
Which is it? Positive or negative? Last edited by geezer#99; 10-22-2020 at 02:02 PM. |
10-22-2020, 05:17 PM | #7 |
Re: camber
Do you have the truck complete is all the weight on the truck such as motors fenders Hood etc and are you using stock springs
10-22-2020, 11:24 PM | #8 |
Re: camber
yes complete truck got 2 degrees positive now no shims not sure what the camber shroud be on heard 0 degrees positive to 2 degrees neg. to 2 degrees positive so not sure where it needs to be got any suggestions
Thanks |
10-23-2020, 09:33 AM | #9 | |
Re: camber
Did you (you/someone you know) do the x-member swap? Can you provide some pictures of the upper a-arms + where they're attached?
10-23-2020, 12:57 PM | #10 |
Re: camber
As far as I can tell it has a 72 cross member
10-23-2020, 01:26 PM | #11 |
Re: camber
OK.
A '72 x-member swaps over w/o issues.
