Old 11-06-2020, 01:06 AM   #1
malc1080
1979-1980 454 suburban emission sticker
i noticed i posted on the wrong section and hopefully i can get help her.
can someone help me out please? anyone own a 1979-1980 suburban (cali
approved not federal) with factory 454 that still has the emission sticker diagram? I really need a picture of it to follow it and put the 454 back to original to pass smog in cali. I was using a 350 1980 emission sticker to get an idea but it is not accurate for me to follow that. thank you!
malc1080 is offline   Reply With Quote
Old 11-06-2020, 02:09 AM   #2
Irish1941
Irish1941's Avatar
Re: 1979-1980 454 suburban emission sticker
'82 is about as close you will get.
https://www.classicparts.com/1982-Em...tinfo/87-348B/
Talk to smog ref and maybe they can help. They want you to PASS!
https://asktheref.org
Posting on every Suburban related thread on 67-72 will not help your cause
Irish1941 is offline   Reply With Quote
Old 11-06-2020, 02:15 AM   #3
malc1080
Thank you for replying! I tried believe me. But they want me to follow the diagram and I don’t have that. They did the swap without following the proper rules and always paid under the table and now I own it and regret buying . So now I’m running around looking for original parts and removing those after market parts we all like to Install . All I need is the emission decal to make sure I’m buying the right parts. Everything else I can find CARB approved parts on the auto repair bureau website.
Old 11-06-2020, 03:28 AM   #4
Irish1941
Irish1941's Avatar
CARB does not need they diagram on rad support.
They KNOW what is supposed to be there and they have the info via the VIN from past registrations & titles. Same with "was a diesel now a gas NO SMOG ever"
Not so...
I talk with CARB 4-5 times a month on swaps and smog stuff.
Now, going back over what you said, "they did they swap and paid under the table"....so illegal smog check after somebody put a 454 in your truck?
Is that correct? If so thats whole 'nother deal.
No sticker is going to help you at this point.
Old 11-06-2020, 10:56 AM   #5
Warrens69GMC
Warrens69GMC's Avatar
http://www.73-87chevytrucks.com/tech...ice_Manual.pdf
