11-28-2020, 06:16 PM | #1 |
Burnouts are therapeutic
Ignition awitch removal
I'm having issues getting the cylinder out of my 70, the cylinder is worn out I think? and the key will come out in any position so if I try to turn it and pull out the cyl the key just comes out. has anyone dealt with this before?
1969 CHEVELLE SS 1972 C10 ALMOST DAILY DRIVER 1968 C10 RUSTBUCKET (MISSION IMPOSSIBLE) 1972 PONTIAC LEMANS CONVERTIBLE (WIFE'S CAR) "My wife and I were happy for twenty years. Then we met." - Rodney Dangerfield "The difference between genius and stupidity is that genius has its limits." - Einstein |
11-28-2020, 06:58 PM | #2 |
Msgt USAF Ret
Re: Ignition awitch removal
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
11-28-2020, 07:15 PM | #3 |
Thanks vettevet , I have watched a lot of videos on it including a guy drilling it out. I have removed several of these over the years but its been a while. I think the issue is the key won't stay in the cylinder because its worn out. I will mess with it again tomorrow
11-28-2020, 07:34 PM | #4 |
You should be able to get a new cylinder and keys from the local parts store.
11-28-2020, 07:37 PM | #5 |
I plan to replace the cylinder when I put the truck back together
11-29-2020, 10:01 AM | #6 |
My 80,s key would pull out as well but my ign. switch on the column started going so after I put a new one in the key doesn,t pull out no more, go figure.
11-29-2020, 05:53 PM | #7 |
Just a thought on replacing the ignition key and cylinder. Various vendors on this site have ignition and door locks keyed the same so you only need one key for the truck.
11-29-2020, 06:21 PM | #8 |
Old member
Are you using the paper clip? If the key isn't staying in try another key. Don't force it in though. Its just to have something to turn the cylinder while you push in on the button.
11-30-2020, 11:36 AM | #9 |
I have a new cylinder and key you can have if you want it. PM me your address if interested and I'll get it out to you.
12-02-2020, 09:12 PM | #10 |
hey thanks for the offer, I am going to buy a matched set with the door locks. I ended up having to drill the cylinder out . thanks to everyone for the help
12-03-2020, 11:12 AM | #11 |
12-03-2020, 11:48 AM | #12 |
If you get a new key cut, it should be cut to a depth standard. They should have higher notches than your current key which has likely worn out over the years.
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
