Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 01-09-2021, 10:24 AM   #1
3QTRTONS
3QTRTONS's Avatar
5500 NAPCO front ???
1969 USAF GMC5500 with NAPCO front axle (7.20 ratio) believe it's an Eaton. What numerically smaller gearset could I use to make this beast more highway-able? It can't be that easy as installing a ring gear/pinion from a rear axle of similar weight rating, can it?
Any input appreciated!
1994 C1500 rclb 1988 C1500 rclb
1969 ES5500 B E A S T 1983 C10 'farm truck'
1976 K20 Suburban 1984 K10 Suburban
1981 Jeep CJ5/350 Vortec
1941 Dodge WC18 Ambulance
2000 GMC Bus (parts warehouse)
3QTRTONS is offline   Reply With Quote
Old 01-09-2021, 12:20 PM   #2
1976gmc20
Re: 5500 NAPCO front ???
Crazy idea: is the wheelbase long enough to install an auxilary OD transmission in the rear drive line ???
When you're using 4wd you probably don't need to go that fast
Current/past Chevy/GMC trucks:
1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD
Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner
1976gmc20 is offline   Reply With Quote
Old 01-09-2021, 10:25 PM   #3
3QTRTONS
3QTRTONS's Avatar
The wheelbase is plenty long enough. Aux o/ds wicked pricey though, aren’t they?
Old 01-10-2021, 12:52 PM   #4
1976gmc20
Sorry, no clue about that. I was just thinking one change instead of changing gears in both (or three?) axles.
I wonder if you could still find an old under/direct/over three speed from the 1950s?
I drove an old GMC with one of those (5x3). You would just have to make sure to be only in direct when engaging 4wd.
Old 01-10-2021, 10:12 PM   #5
sweetk30
sweetk30's Avatar
if you have wheel base length put the browny box after trans but before divorced rockwell t-case .
but the bigger problem is these old trucks were NOT made to do long distance speed or todays highway speeds . the brakes are not as good as todays and other problems can show up .
i did a 4x4 napco swap for my old boss and it tops out 45-50 mph safe and decent rpm range . i dont think i would want to go much faster on them old driveline parts .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 01-11-2021, 07:44 AM   #6
3QTRTONS
3QTRTONS's Avatar
REALLY appreciate the replies! All good info, for sure. There isn't a whole lot left around these parts; this truck was definitely a strange bird right from the start. I have a set of one ton (4.10) axles from an '89 V3500 SRW that I could use - would 'bob' the frame by several feet and dump bed or flat bed it. That would make it more of a pickup than a Heavy Hauler, but would be more usable on the highway. I've seen on here that the 1 ton idea has been done. More research I guess!
Old 01-11-2021, 01:18 PM   #7
1976gmc20
What size tires do you have now?
If say 8.25-20 maybe go to 900-20 or 1000-20 for a little less highway rpms ???
(I hate seeing these big trucks cut down )
Old 01-11-2021, 03:57 PM   #8
MJN
MJN's Avatar
I don't have any documentation for Napco stuff newer than 1960 but in my Napco parts book it shows a 6.17 ratio available for '56-57 1.5 and 2-ton trucks, no idea if they continued to offer this later on. For pickups Napco only offered one ratio; 3.90 for 1/2tons, 4.57 for 3/4tons and 5.14 for 1 tons.
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 01-12-2021, 07:10 AM   #9
3QTRTONS
3QTRTONS's Avatar
Presently 9.00x20 - Originally equipped with a 292 I6. Even with 12.00x20, the rpm would be 'howling' at highway speed (3,574 @ 65 mph).
The heaviest Hauling planned is a car trailer with a Military Ambulance for Shows and Parades.
Old 01-12-2021, 06:19 PM   #10
1976gmc20
I never drove my C/50 much over 50 mph. Was up in the mountains and back then the max limit was 55. I was warned about over speeding the big V-6 but hardly ever had a place to go that fast anyway. I bought another engine with a big hole in the side of the block just for the extra parts: heads, manifolds, carb, power steering, etc.
You might get a laugh out of our old 6x6 army water tenders going down the highway at 45 mph with the emergency lights flashing and all the rest of the traffic passing instead of pulling over
Old 05-01-2021, 06:50 PM   #11
Dannny B
I've got a 4 speed Browny that I will let go of.
Dannny B is offline   Reply With Quote
