Old 01-18-2021, 06:53 PM   #1
BigBlockBurris
BigBlockBurris's Avatar
Help Me Identify This PS Pump Please!
I have been cleaning out the garage for a move, and I have found a bunch of stuff I will be selling in the near future. This was mixed in with 67-72 truck parts, but I believe it is 73-up truck. Please note the 3 ports on the back of the pump, which I believe would be for hydro-boost.
Thoughts? Opinions?
Thanks in advance!!!
BBB
BigBlockBurris is offline   Reply With Quote
Old 01-18-2021, 06:54 PM   #2
BigBlockBurris
Re: Help Me Identify This PS Pump Please!
Other side.
Old 01-18-2021, 07:37 PM   #3
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Help Me Identify This PS Pump Please!
Those are for the BB engines, 454 and such. I have seen them on 71/72 trucks not sure if they where stock though. I'd love to have one on my SB truck for the easyness of filling it up.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 01-18-2021, 08:46 PM   #4
roboticjunky
Base on Rockauto, it's 1980-1991 1 ton square bodies with 454.
6.2 diesels had one of the lines on the side so it's not for it.
roboticjunky is offline   Reply With Quote
Old 01-18-2021, 09:39 PM   #5
BigBlockBurris
Thank you both. I knew it was BBC, and I thought it was for hydroboost.
Old 01-18-2021, 09:45 PM   #6
roboticjunky
The pump is for hydro boost. Like you said because it has 3 ports on the back instead of 2 ports.
Old 01-22-2021, 10:33 PM   #7
c1971
I think it maybe from a mid 80's van. It has the metal remote reservoir and V belt pulleys. I only remember seeing the remote reservoir on vans.
c1971 is offline   Reply With Quote
Old 01-23-2021, 10:33 AM   #8
Mike C
Mike C's Avatar
Big block hydroboost truck. The remote reservoir is great. I have an '83 big block C2500 with vac brakes and it has the integral reservoir which SUX. I lays the pump body over 45 degrees and makes adding fluid a PITA. The remote on my other trucks (including the 71 GMC 402!) is great. I even bough a repro to use on the big block swap into my 64 'vette.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
