Old 01-20-2021, 03:12 PM   #1
Friday
Vapor Canister Question
1994 C1500 5.7L AT. Noticed a rat chewed the purge fitting off the vapor canister. Anyone know if the top can be replaced on this, or any way to repair it?
Friday is offline   Reply With Quote
Old 01-21-2021, 01:19 AM   #2
EVRLET
EVRLET's Avatar
Re: Vapor Canister Question
I’ve never seen just a top replacement. Maybe you can grind it so the fitting is straight up, versus 90 degrees, and then possibly clamp the hose to it.
Or pay like $80 for a new one.
Customization is what you want it to look like -- not what other people think it should look like
EVRLET is offline   Reply With Quote
Old 01-21-2021, 01:37 AM   #3
Friday
Yeah, I've seen the prices . . . damn. Guess it's time to bring out the Yankee ingenuity.
Old 01-21-2021, 12:56 PM   #4
sntrym95
sntrym95's Avatar
These have to be a dime a dozen in the boneyard.
Mike
sntrym95 is offline   Reply With Quote
Old 02-14-2021, 07:26 PM   #5
diveplane
what does that do anyway? do u need to replace that?
diveplane is offline   Reply With Quote
Old 02-16-2021, 06:37 PM   #6
sntrym95
sntrym95's Avatar
It's required for emissions. It collects fuel vapors and then peridocally releases them into the injection system to get burned instead of having them evaporate in the atmosphere.
You could technically vent the tank to the air but you'll have a fuel smell and depending on where you live, won't pass emissions inspection.
Mike
Old 02-17-2021, 08:44 PM   #7
71gmcC15
71gmcC15's Avatar
In my 94 I by passed it all together. Just connected the two lines together and whent stait to the tbi. Never had a issue. Only reason I did this was to fit the under hood tool box the 95 ups got.
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original )
94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless
07 gmc sierra classic rcsb 4.3 lt 5 speed w/t
04 chevy Silverado 1500 ext cab 5.3 4l60e.
81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green)
71gmcC15 is offline   Reply With Quote
Old 02-19-2021, 09:42 PM   #8
diveplane
canister ever need replaced though? does it improve performance?
Old 02-19-2021, 10:58 PM   #9
Just call me Sean
Just call me Sean's Avatar
It stores fuel vapor to be burned later, so to really sell it you need to mention that it increases your fuel mileage a tiny bit.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
