Old 02-02-2021, 05:31 PM   #1
fishmunger
fishmunger's Avatar
3.73s with 35s 72 K10 Th350 Auto & stock 350?
Finally got my project K10 on the road! It currently has 35s (small ones - actual diameter 33.5 or so), th350 auto, stock 350 that runs good, and it just sings going down the highway!
It's going to be my "backup" work truck which means it will probably see 3-4k miles a year, and 50% of those will be towing a smallish, (20' - 4000# total) boat w/ trailer (I'm in the fishing business). It will very occasionally have to tow a 6000lb boat/trailer, but those times will be few and far between, and mostly short distances (the overall size of this truck is simply too small to tow a load that size regularly/long distance in my opinion. Truck will also see some offroad trails throughout the year, but nothing crazy, no rock crawling type stuff.
Most of my commuting and towing is on the highway, fairly flat, only one good grade I encounter with some regularity that will likely require a downshift.
Currently its takes 2500-3000 rpms to go 55-65 down the highway, way too high. I was originally leaning towards 4.11s, which seems like a pretty common setup for this combo, and would drop my rpms by about ~300 at a given speed.
But after talking to a very knowledgeable local mechanic who has a 72k5 of his own, and works on lots of 4x4s, he thinks I'd be better off with 3.73s. His argument is that would put my rpms right where I want it most of the time, 2000-2500 on the hwy. And would make 2nd gear 'perfect' when I go up a big grade - just downshift a gear. He thinks 4.11s would be OK, but would be just a 'little bit too low' almost all the time - and the 2nd gear would be too low to downshift into on the hwy. Whereas, the 3.73s would only be a 'little bit high' occasionally. And for the trails, I can just use 4 low if it's a tad sluggish.
I think his points are pretty interesting? I hadn't thought about the downshift into 2nd factor...
Just wanted to get as many opinions as possible before I drop $3500 regearing and rebuilding both axles with new gears and trutracs front and rear...
fishmunger is offline   Reply With Quote
Old 02-02-2021, 06:04 PM   #2
57taskforce
All about them K’s
57taskforce's Avatar
Re: 3.73s with 35s 72 K10 Th350 Auto & stock 350?
With the weight your wanting to tow I think I’d stick with 4:11’s. If you had a 4 speed with granny to get you out of the hole, 3.73’s might be an ok option. I just don’t think the 3.73 would be ideal for towing with 33’s or 35’s, second gear might line up but it’s gonna be a dog off the line with a trailer behind it... That’s just my opinion though.
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
57taskforce is offline   Reply With Quote
Old 02-02-2021, 08:19 PM   #3
There is very little difference between the two ratios. To me the one with the most advantage for your uses would be 4.10s, especially considering your taller than factory tires. With 35s and 4.10s on a truck that originally had 31" tires you end up with right about 3.73 ratio. I wouldn't want less than that to tow or haul weight
Old 02-03-2021, 02:32 AM   #4
Jcfcamaro
Jcfcamaro's Avatar
I'm getting ready to do the same with my 72 k10 with the same drive trane. Doing all the transmission calculators online it seems like the 3.73 is a good fit for me, but I'm going to see what the guys on here say. When you get ready to order parts check out Quick Performance out of Ames Iowa they have really good prices and a great tech line for help. Also sell package kits . That's where I'll be buying my stuff.
Jcfcamaro is offline   Reply With Quote
Old 02-03-2021, 05:16 AM   #5
mongocanfly
Post Whore
mongocanfly's Avatar
what gears do you have now? must be fairly low
and what rpm do you want to turn at say 65mph?
the gears you stated are gonna give the rpms your saying are to high..
3.73-33.5-1:1-65mph=2432rpm
4.11-33.5-1:1-65mph=2679rpm
I would look more towards a od trans with a lower axle ratio to get the best of both worlds
hers the calc I use ..just fill in blanks at bottom of the page..
http://www.csgnetwork.com/multirpmcalc.html
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 02-03-2021, 08:40 AM   #6
cadillac_al
My 76 K10 350/th350/30"tires tows 6000 lb trailers with 3.08 gears and I don't need to downshift for hills. I wouldn't worry about the downshifting aspect.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 02-03-2021, 01:00 PM   #7
fishmunger
fishmunger's Avatar
Currently the truck has 4.56s, and it's in 3rd gear at about 15 mph going down the road! Takes 3000 rpms to go 65, even at 2500 its barely pulling 55 and I'm practically getting run off the highway...
Old 02-03-2021, 01:10 PM   #8
fishmunger
fishmunger's Avatar
cadillac al - Are you satisfied with your setup for towing? How is your off the line response? Your effective ratio is pretty similar, actually slightly higher, than what I would be looking at with 3.73s
Old 02-03-2021, 08:20 PM   #9
1976gmc20
Must not be very steep hills. My old 350/350 K trucks wouldn't even climb the hills in Colorado in high gear when empty
And one I bought brand new. The other was in the family since new and I got it at about 12 years old, maybe 65K miles.
Maybe altitude makes a difference ???
Current/past Chevy/GMC trucks:
1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD
Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner
1976gmc20 is offline   Reply With Quote
Old 02-03-2021, 10:05 PM   #10
Mike C
Mike C's Avatar
3.73 and 35" tires are a great choice with a TH350. Same setup we did in my kids Jimmy. And if you had a manual trans you'd probably like the 4.56.
Based on your description of use, I'd go with the 3.73. On my kids truck we also did a 204/214 cam with an Edelbrock intake and dual exhaust on 2.5" rams horns so a little more power than stock.
Converter slippage is a factor making 3.73 and a TH350 almost same highway rpm as an sm465 and 4.10 which is my favorite road combo.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-03-2021, 11:27 PM   #11
Zoomad75
K5Camper
Zoomad75's Avatar
If hills or mountain grades are in the plans for driving, I'd error on the side of more gear.
I've lived with 350/465/3.73 on 35's here in Colorado. Flat ground it was ok, but anytime the grade went up the poor little 350 was struggling to maintain speed.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 02-04-2021, 08:36 AM   #12
4u2nv
That's the rpm I'm getting at the same speed with 4.11's and 35's , It's off the line like a rapped ape and through 2nd in a flash , I shouldn't think that there is any thing to worry about for towing except your gas mileage.
4u2nv is offline   Reply With Quote
Old 02-04-2021, 10:06 AM   #13
57taskforce
All about them K’s
Are you sure your rpms are the same? Mine has 4:11’s, Sm465 with 1:1 4th gear, and 31.5”ish tires on it and it doesn’t quite pull 3K@65. With 4:11’s and 35’s
You should be closer to 2500@65, and 2100@55. That’s of course assuming a 1:1 transmission high gear.
Tyler
Old 02-04-2021, 02:31 PM   #14
fishmunger
fishmunger's Avatar
Thank you for all the responses!
Mike C - I'm curious, did your kid's rig see any towing?
Old 02-04-2021, 04:45 PM   #15
1976gmc20
I once had a 350/465/3.07 and oddly enough it did all right. Pulling my trailer up a hill you could just shift down to 3rd and keep right on going. Of course the speed limit was 55 in those days but it would run 55 in 3rd without any complaint. Solo it would get 18 mpg at 55 and 15 mpg at 80. You pretty much had to leave it in 3rd driving around town; 4th(H) was effectively overdrive.
Pulling my Cat on a rented trailer over Monarch, it did just fine in 2nd gear at 30-35 mph. Coming down was frightful though! I never did that again. I bought a Real Truck and had to sell the K10 to pay the bills.
Old 02-06-2021, 07:39 AM   #16
4u2nv
350 turbo tranny
Old 02-06-2021, 10:37 PM   #17
Mike C
Mike C's Avatar
It has not seen any towing, but I don't see any reason it wouldn't do well at it.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 02-07-2021, 04:45 PM   #18
i82much
I have a 1972 K10 with 3.73s, 32 inch tires, TH350, and a 396. It’s pretty good all-around but if I had to open up the axles for some reason I would swap in a little steeper gear like 4.11.
It’s hard for me to see how a 350 would do any better than my 396, so my guess is you’d want more gear than 3.73?
i82much is offline   Reply With Quote
