Old 02-14-2021, 07:10 PM   #1
diveplane
LO5 V8 coolant lines and transmission line
after ages searching think i found the coolant lines for the v8 truck mine are leaking
this the right ones guys?
lower oil coolant line
https://www.oreillyauto.com/detail/b...ckup-rwd?pos=1
upper oil coolant line
does mention this without axle ratios 2.73, 3.08,3.42,3.73
what is my truck? 1992 standard cab 2 door silverado 5.7 V8 automatic
8 foot bed.
looking for the AT line for other side part number for that, only one line that side?
diveplane is offline   Reply With Quote
Old 02-14-2021, 07:19 PM   #2
diveplane
Re: LO5 V8 coolant lines and transmission line
https://www.ebay.com/itm/39217011434...xoCB0oQAvD_BwE
this the correct AT lines i know i have 700r4 tranny by checking RPO CODE.
Old 02-14-2021, 07:51 PM   #3
Just call me Sean
Just call me Sean's Avatar
I deleted my oil cooler. The crappy push connectors leaked even with new lines. The older trucks had threaded fittings on both ends.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 02-14-2021, 07:59 PM   #4
diveplane
ok looking for parts that work any ideas fit this truck..
Old 02-14-2021, 09:14 PM   #5
Just call me Sean
You probably need 625-139 and 625-140.
Old 02-19-2021, 09:43 PM   #6
diveplane
ok thx seen a few videos now how to correct the issue of the quick connect fittings.
Old 02-19-2021, 10:55 PM   #7
Just call me Sean
Those are the two options I thought were the best. Delete the oil cooler with an oil filter adapter from an engine without it. I had one. Or use an oil filter adapter from an older truck which has threaded connectors instead of the push ones. I also have one of those, but I didn't want to buy lines so I deleted it.
