Old 02-26-2021, 09:04 PM   #1
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Are these the right height
I ordered these 4 inch drop springs and although correct part number on them they just look too short for a 4 inch drop. They are 9 inches high. Can anyone tell me for sure if they are the right ones for a 4 inch drop. It amy be a whie before I install them so want to make sure they are correct while I can still return them if not correct.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 03-03-2021, 06:56 PM   #2
67C10Step
67C10Step's Avatar
Re: Are these the right height
Sorry for the long delay in response to this. Those are the exact springs I put in the back of my 67 for a 4" drop. Photo below. Mine will obviously drop a bit more when I put the bed on it but this appears about right with the 2.5" drop in front that hasn't totally settled out just yet.
I also purchased some shortened bump stops for the rear and there is just a hair over 3.5" of clearance between the stop and the axle housing.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 03-03-2021, 09:08 PM   #3
Already Gone
Thanks for the info. For your front 2 1/2 inch drop are you just using the dropped spindle with stock spring or a 2 1/2 inch dropped spring. Also what size tire you running front and back.
Old 03-03-2021, 09:39 PM   #4
67C10Step
67C10Step's Avatar
Standard height spring in front with 2-1/2" drop spindle. I wanted to keep the steering geometry as close to stock as possible. I've not driven my truck yet and I expect the front to settle a bit more since the springs are new as well.
I am runnin 255/70-15 all the way around.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
Old 03-03-2021, 11:48 PM   #5
Already Gone
Thanks again. 255/70 15's are 29.04 inches high. I plan to run 255/60 17 which are the same height as your 255/70 15's and use a 2 1/2 inch spindle like you are and I like what tire to fender clearance you have up front. I'd like to see your truck when you get the box installed.
Old 03-04-2021, 09:06 AM   #6
67C10Step
67C10Step's Avatar
Will do, mine is going step side. I got the wood for the bed a week or so ago an am going to pull the trigger on the whole box from Mar K soon. I'm anticipating the rear to drop another 1/2" or so when the bed is on and the front to settle about the same when the suspension articulates a bit.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
