Old 04-20-2021, 10:49 AM   #1
spudder
Active Member
Bill's '64 Project................
For the past year, my friend Bill and I have been working on his '64 short bed. The truck was an older restoration and had several paint issues than would have required a total repaint which was cost prohibitive. Instead, Bill decided to do a faux-patina theme and use his money to refresh the mechanicals and add several options.
Here are some pictures of the truck.
The suspension has been rebuilt and upgraded with '79 control arms, disc brakes, drop spindles up front and 3"" drop springs with 1' lowering blocks in the rear. We machined the rotors and re drilled them and the axles to 4 3/4 bolt pattern. The wheels are 15 X 7 68' Corvette AG code rallys.
I'm amazed how well the truck rides and drives!
spudder is offline   Reply With Quote
Old 04-20-2021, 11:04 AM   #2
spudder
Active Member
Re: Bill's '64 Project................
The engine is a stock early '70s 350 with a turbo 350 transmission. A 700R4 is planned later. The power steering pump setup is from a '72 truck. The washer fluid bottle/pump is from a '86 Suburban. The cruise control is early70s Chevrolet passenger car. We added a set of 4 horns from an early '90s Cadillac.....they will get your attention.
Old 04-20-2021, 11:17 AM   #3
spudder
Active Member
Moving inside the truck we added several items. The tilt column is from a Chevy motorhome. The parking brake pedal is out of a mid '80s Chevy pickup. We modified the kick panel vents with pull handles from a '72 pickup. The under dash AC vents are from a mid '60s Pontiac. I added under dash speakers using front speaker brackets out of a late '80s suburban.
Old 04-20-2021, 03:22 PM   #4
Ronzo
Ronzo's Avatar
Beautiful job.
Ronzo is offline   Reply With Quote
Old 04-20-2021, 06:13 PM   #5
SCOTI
SCOTI's Avatar
Cool use of alternative vehicles parts.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-22-2021, 10:05 AM   #6
spudder
Active Member
Here is an update showing how we ran the exhaust. We wanted it tucked up higher rather than run below the crossmembers.
Old 02-10-2022, 09:16 PM   #7
SidsChopShop
Very nice build, would be interested to know your tire sizes. thanks in advance.
SidsChopShop is offline   Reply With Quote
