C30 Dually LB convert to Shortbed
I have a 157 inch wheelbase chevy Cheyenne dually. I want to convert it to a shortbed stepside. Has anyone done this?
Do you have any pics, threads or any info on a transformation like this? |
6>8 Plugless........
![]() Join Date: Sep 2007
Re: C30 Dually LB convert to Shortbed
I know it's been done many times. Does your truck currently have a bed?
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
No i remove the old one and i just bought a short Stepside bed with custom hole for the dually
Currently Blazerless
I thought of doing it using a long stepside bed, the problem is the higher kickup in the 157" chassis. I believe its a 2" higher kick so you will have to raise your cab that amount for body lines to match up. It would be much easier with the 133" C30 chassis which shares the same amount of kick as the 115"/127" chassis.
Do you have a pic of your custom bed? Im not sure what you mean by a hole for the dually?
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
I agree with Blazerman. You need to find a 127' longbed frame with running gear and cut it down. Should be fairly cheap and easy score. May find someone who wants to build a C30 hauler and they would appreciate the uncut frame and running gear.
![]() ![]() Join Date: Jan 2015
If you want a one ton frame find a longhorn frame and cut it down 18” works well. Here is a longhorn frame I cut down and then converted to a 4x4 with one ton axles out of a 81 K/30 square body
