Old 04-24-2021, 09:13 PM   #1
72farmer
What else do i need to make this steering wheel work?
I have a 87 that has a Grant steering wheel. I have never liked it. I got one from a 88-94.
How do i deal with making the horn work? The horn button has 2 spade terminals on it. What do i need and does both spades have to have a wire going to them?
72farmer is offline   Reply With Quote
Old 04-24-2021, 10:26 PM   #2
Just call me Sean
Just call me Sean's Avatar
Re: What else do i need to make this steering wheel work?
You need the wire that inserts into that white part sticking out at the bottom. It has a plastic piece with nubs that lock it in like a bulb.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 04-25-2021, 09:21 AM   #3
72farmer
I have 2 male spades on horn button. So plug the new horn wire on one of the spades on the horn button. What goes to the other spade on the horn button?
Old 04-25-2021, 10:23 AM   #4
f.monroe
f.monroe's Avatar
Ground one terminal and hook the other to the original horn wire .
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 04-25-2021, 12:16 PM   #5
Just call me Sean
There is only one terminal. Your button is broken. The tab that holds the button on is broken.
Old 04-27-2021, 07:19 AM   #6
72farmer
Thanks, I see where mine is missing the little tab that goes to ground on steering wheel hub. Can i just put a small jumper wire from what is left of the tab to steering wheel hub?
Drill and thread hub for a ring wire terminal and use a female spade at button?
Old 04-27-2021, 11:46 AM   #7
Just call me Sean
I didn't think the tab was a ground but I guess it does ground through the wheel with that tab. A wire will work.
Old 04-28-2021, 01:27 PM   #8
Wgesnerjr
Wgesnerjr's Avatar
I think you need one of these.
Jay Gesner
Atlanta, GA
1985 C10 Long Bed 4X2
LS 5.3, 4L60E
Father/Daughter Project
Wgesnerjr is offline   Reply With Quote
Old 04-28-2021, 04:41 PM   #9
71gmcC15
71gmcC15's Avatar
If you wire up the ground then the horn will be one all the time. I uses that tab that's broke to contact the center bolt when pushed chosing the horn to go off. So wiring a ground to it would make the horn go off continuously.
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original )
94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless
07 gmc sierra classic rcsb 4.3 lt 5 speed w/t
04 chevy Silverado 1500 ext cab 5.3 4l60e.
81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green)
71gmcC15 is offline   Reply With Quote
Old 04-28-2021, 08:38 PM   #10
Just call me Sean
No, the tab grounds to the steering wheel shaft. Pushing the button completes the circuit, completes the ground.
