04-30-2021, 09:10 AM | #1 |
door striker pic request
I have to fix my rotten door striker mounting section on door frame but can,t find a pic of stock door frame to see how big the hole is for the striker for adjustment . Is on a 78 blazer
05-01-2021, 09:08 AM | #2 |
Re: door striker pic request
this what i have, I trimmed out for the new patch but I know where the striker goes is a larger hole but I don,t how big it is. I do have the threaded block for it, it is out for now
05-01-2021, 09:28 AM | #3 |
Post Whore
Can you not measure off the drivers side?..
05-01-2021, 08:53 PM | #4 |
Well as mongocanfly has said. Because you should take a look at it. Because the square if I recall right it moves in side about a 1/4" all around for Adjustment’s of the striker to line up the door. And the big washer covers the hole ( so the hole smaller then the washer but bigger then the bolt) I would put your hand behind feel how it finished there.
Ho just the square is open just remembered
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. Last edited by Pontiac1976; 05-01-2021 at 08:59 PM. |
05-01-2021, 09:12 PM | #5 |
Well stupid me , the striker bolt will only slide around the sq. hole inside, so the new plate will have to have the same sq. hole which is 3/4x3/4 . Match new plate up and center and weld it up. Over thinking that one .
05-01-2021, 10:48 PM | #6 | |
So try not to beat yourself Up I was going to take measurement from a scrap cab I have. Then mongocanfly came to the rescue You can do this. .
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
