Old 05-20-2021, 04:35 PM   #1
yellowGT
yellowGT's Avatar
90-91 suburban cluster swap issue
So I did the swap and thought it was all good. Then I go to start the truck and the speedo starts acting like a tach. Yes, a tach. I smash the accelerator and the speedo needle moves. This is happening with the vss wire coming from ecm to pin 18 on the cluster plug. What did I do wrong? Mind you that the white tach wire from ecm is not spliced in to anything.
yellowGT is offline   Reply With Quote
Old 05-20-2021, 07:22 PM   #2
wildwilly4x4
Re: 90-91 suburban cluster swap issue
is the trans in gear but driveline not installed? Positive and double checked the pin locations? I haven't wired one up myself, but I am in progress on an 8.1 swap in an '84 C10. I have swapped other trucks, but they were all cable drive speedos.
wildwilly4x4 is offline   Reply With Quote
Old 05-20-2021, 07:29 PM   #3
wildwilly4x4
Which PCM are you using?
Green/ Blue connectors show pin 50 on the green connector for electronic speedo (green/ white trace)
Red/Blue connectors pin 50 on the red connector is what should go to the speedo.
