Old 05-31-2021, 11:15 AM   #1
Captain J
Rochester QuadraJet 4bbl Carburetor issue
Hello
My truck (1986 GMC Sierra K2500 with 5.7L) have issues with starting, engine will crank but it’ll not start, I replaced the fuel tanks, new sending units, new fuel hoses, new fuel pump, new fuel filter, rebuild the stock carburetor (Rochester QuadraJet 4bbl), fuel comes to the carburetor.
Issue:
It will start if I put fuel in the carburetor for the 1st of the day, subsequent starts are ok. If I leave the truck overnight, next day it’ll not start (it’ll crank, but no start).
Need help
1972 GMC Sierra C2500, V8-350
1986 GMC Sierra C2500, V8-454
1986 GMC Sierra C2500, V8-LS1
1986 GMC Sierra K2500, V8-350
1987 GMC Sierra R3500, V8-454
1997 GMC Sierra K2500, V8-454
Captain J is offline   Reply With Quote
Old 05-31-2021, 11:23 AM   #2
geezer#99
geezer#99's Avatar
Re: Rochester QuadraJet 4bbl Carburetor issue
If filter in carb was replaced was it installed right?
Sorry, delete that question. Filter must be good from your description.
Does your choke work?
Any fuel from the accelerator pump when you pump it first time when cold?
Could be leaking fuel bowl wells also.
That’s not normally a problem with your carb though.
How new is the fuel pump?
Old 05-31-2021, 12:49 PM   #3
Captain J
Thanks for replying
Filter is installed correctly,
Choke is electrical but how do I test it? Because it starts no idle after starting,
Not sure about the accelerator pump, do I look inside the primary to see if fuel comes out?
Fuel pump is less than a month old (brand new)
I didn’t do the rebuild myself, someone else did it.
Old 05-31-2021, 01:00 PM   #4
geezer#99
geezer#99's Avatar
Yup!
Look in the carb. Hold the choke blade wide open. Stroke the throttle quickly. Look for fuel beside the boosters. Up near the top front. Should see two shots. One on each booster.
To check choke open throttle 1/4 way and choke flap should move and close off top of primaries.
Old 05-31-2021, 01:14 PM   #5
Captain J
Yup!
Ok 👍🏻
Is that with ignition off or on?
Old 05-31-2021, 01:18 PM   #6
geezer#99
geezer#99's Avatar
Off.
Sometimes easier to use a small flashlight to see inside the carb.
Old 05-31-2021, 01:45 PM   #7
Captain J
Off.
Ok
Old 06-01-2021, 10:42 AM   #8
Captain J
Off.
Update
I’ve not started the truck for the past 5 days,
Today before starting I checked to see if i can see fuel is squirting inside the carb if I push the paddle, and it did.
So I cranked the car, fuel stopped squirting,
So I waited for few minutes I repeated the process
Pushing the paddle without cranking, and nothing, no fuel coming
I’ll check after few hours.
Old 06-01-2021, 10:53 AM   #9
geezer#99
geezer#99's Avatar
It only squirts when you stroke the throttle
It should squirt every time you stroke it.
If not (like in your second test), then the pump well is low, float level is low. And possibly the check ball is stuck.
Will the choke blade close when you stroke the throttle?
Old 06-01-2021, 11:13 AM   #10
Wgesnerjr
Wgesnerjr's Avatar
IIRC, there is a spring in with the fuel filter. Make sure you have it on the correct side of the filter. Also double check that the filter is going the right way.
I did this once when I was young and had to pay a mechanic to put it in right.
If you have a paper filter make sure the end with the hole is going towards the fuel line, opposite the spring.
Jay Gesner
Atlanta, GA
1985 C10 Long Bed 4X2
LS 5.3, 4L60E
Father/Daughter Project
Wgesnerjr is offline   Reply With Quote
Old 06-01-2021, 11:19 AM   #11
Captain J
The choke blade was wide open before I do the test, and stayed open while I moving the throttle.
Old 06-01-2021, 11:21 AM   #12
kwmech
Well plugs in the bottom of the bowl could be draining overnight. Quite common area to fix when rebuilding the carb. Mix up some JB weld--apply and wait a few hours
Old 06-01-2021, 11:21 AM   #13
Captain J
I’m positive it’s, but I rechecked it aging,
Old 06-01-2021, 11:36 AM   #14
geezer#99
geezer#99's Avatar
Should have closed.
We’ll help fix that but first a question.
When you do get it running and when driving down the road and you step on the pedal, do you feel a slight stumble?
Old 06-01-2021, 11:47 AM   #15
Captain J
That’s something I’ll do thanks
Old 06-01-2021, 11:48 AM   #16
Captain J
Should have closed.
No, it runs fine, subsequent starts are also ok
Old 06-01-2021, 12:08 PM   #17
geezer#99
geezer#99's Avatar
The black cap on the side of the carb should have 3 screws on it. Loosen them and rotate the cap counter clockwise. Hold the throttle open and the choke blade should close. Turn it until it just closes then tighten the screws.
That should help starting.
I’d do that first.
If it helps the no start situation then you know the well are good.
Old 06-01-2021, 01:17 PM   #18
Captain J
I’d do that first.
Ok, thanks
Old 06-01-2021, 02:50 PM   #19
Captain J
I’d do that first.
Updates
The fuel pump works,
The fuel filter is correct
I turned the choke cap to the left, it only turned less than 1/4 turn.
Truck started but with stuck full throttle, I shut down.
I checked the throttle cables they’re ok, throttle moves ok, gas paddle moves ok.
Started again, full throttle.
I moved the choke cab back to where it was,
started again, full throttle, shut it down,
So I gave up, 😡😤
Old 06-01-2021, 03:43 PM   #20
geezer#99
geezer#99's Avatar
It’s likely still on high idle.
There’s a high idle screw under the choke pull off pot on the front passenger side.
It’s a Phillips head screw. A little hard to see.
Rotate it ccw a couple turns and try again.
See how that works.
Old 06-02-2021, 10:21 AM   #21
Captain J
I’ll tonight and see what happen,
Question
Where can I buy stock or rebuilt Rochester QuadraJet 4bbl for 1986 GMC Sierra C/K2500 with 5.7/7.4L engines?
Old 06-02-2021, 10:32 AM   #22
geezer#99
geezer#99's Avatar
What’s your budget like?
Any rebuilt might not run very well. Depending on your carbs original set up. Different jetting, rods, etc.
Can you post a pic of yours?
Old 06-02-2021, 11:03 AM   #23
Captain J
It took more than 4 ccw to get the idle correct, truck started for the 1st time without any help 😁 thanks to you all for the help
Pictures will be uploaded shortly
Old 06-02-2021, 11:13 AM   #24
Captain J
Pictures
Old 06-02-2021, 11:14 AM   #25
geezer#99
geezer#99's Avatar
Awesome!
Where in the world do you live?
