Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 06-06-2021, 10:32 AM   #1
cwcarpenter98
cwcarpenter98's Avatar
65 C20 rolling frame
This frame was from a GA truck that drove to SC around 15 years ago. Not long after that trip, the owner pulled it apart to use the cab and front end to build a short bed truck. I bought the frame and bed to put the bed on my truck, but I don't need the frame. It was just easier for me to drag both home instead of pulling the bed apart at the guy's house.
The only damage that I have seen is the front crossmember has been pulled forwards. It probably got stuck in a field and was yanked out with a tractor. The rear frame rails are nice and straight. It is a coil spring rear.
Comes as a rolling frame without any of the bed parts. I can get better pictures if needed
$500 obo
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 06-19-2021, 04:10 PM   #2
cwcarpenter98
Re: 65 C20 rolling frame
Here's some better pictures. I finished getting all the bed stuff off, so as you see it in the pics in this message is what you'll be getting. It's currently located at the Truck Farm in Canton, GA (Flashed's place)
Christian Carpenter
Old 06-19-2021, 08:16 PM   #3
Getter-Done
Getter-Done's Avatar
Just a suggestion
It would probably help the sell (Or not)
If you had time to pull the cover and check the gear ratio.
84 Chevy K-20
Old 06-19-2021, 11:18 PM   #4
cwcarpenter98
Originally Posted by Getter-Done View Post
Just a suggestion
Good point! I didn't think to check when I was there today. I'll have to go check it out soon
Christian Carpenter
Old 06-21-2021, 08:16 AM   #5
Madkidd007
Madkidd007's Avatar
I was ajctually about to ask you just that. If you can find out open or locker and the ratio I may be your buyer on it
70 C10 highschool truck now C20 cummins powered
72 Crew Denali, Bigger, Stronger, Faster, well you get the point.....
the ole 65 continental
Syclone killer AWD T56 LS
Paypal please pay as Goods&Services Madkidd00000007@yahoo.com
Madkidd007 is offline   Reply With Quote
Old 06-21-2021, 12:01 PM   #6
cwcarpenter98
I should be able to find out this weekend
Christian Carpenter
Old 06-28-2021, 12:56 PM   #7
cwcarpenter98
Madkidd, sorry for the delay on finding out what ratio the rear is. This week is my last week of summer classes, so that's taken priority of truck stuff. I'm done with class on Thursday, so I'm planning on going to check Thursday afternoon/evening
Christian Carpenter
Old 06-29-2021, 01:57 PM   #8
Madkidd007
Madkidd007's Avatar
You know me. No rush
Old 07-06-2021, 09:26 PM   #9
cwcarpenter98
4.57 gears, looks like an open diff
Edit to add:
So I looked up some info and pictures to learn a little more about the Eaton. It definitely looks like an open diff to me.
I'm open to offers on the whole frame. I don't have the time right now to part it out
Christian Carpenter
Old 07-11-2021, 02:23 AM   #10
cwcarpenter98
I'm open to offers on this frame. I would consider parting out if I have enough interest in what's there
Christian Carpenter
Old 07-11-2021, 09:23 AM   #11
GranPanteraRoja
Luchador
GranPanteraRoja's Avatar
I may be interested in the rolling frame. Do you know how the front suspension interfaces with 63-66 C10 frames? I am considering an 8-lug conversion but didn't know if the C20 components were an easy swap or not onto a C10 frame.
GranPanteraRoja is offline   Reply With Quote
Old 07-11-2021, 11:25 AM   #12
cwcarpenter98
From what I understand, the front suspension crossmember bolts to the frame the same way on both c10 and c20. The rear is easy because it's a trailing arm rear, so all the stuff is similar, just heavier duty to handle the extra weight
Christian Carpenter
Old 07-15-2021, 11:18 PM   #13
cwcarpenter98
If you're interested in a part off this frame, please post what you're needing. If there's enough interest in parts, I will part it out.
Would rather sell it whole though. Got plenty to do on my truck
Christian Carpenter
Old 07-19-2021, 10:05 PM   #14
cwcarpenter98
$400 for rolling frame
Christian Carpenter
Old 07-21-2021, 10:47 PM   #15
cwcarpenter98
If you need just a part or two:
4 wheels: $100
Drum brake complete front crossmember: $50
Rear C20 springs: $50
C20 trailing arms: $150
Rear axle: $150
Inline 6 exhaust: $50
Unfortunately, I think shipping any of this would be way too costly except for the springs maybe
Christian Carpenter
Old 08-21-2021, 11:05 PM   #16
cwcarpenter98
Still available. I'll be back in Canton for the weekend of the 27th to make a deal.
Christian Carpenter
Old 11-17-2021, 10:57 PM   #17
cwcarpenter98
Still available.
I found a section of frame local to me that has C10 rear cab mounts. I will throw those in with the deal for my asking price.
I can deliver the frame if you're within a 100 mile radius from Canton for $100 extra.
If you're along my drive between Canton and Milledgeville on the weekend after Thanksgiving, or near the Milledgeville area, we can work something out.
Christian Carpenter
Old 12-11-2021, 06:31 PM   #18
cwcarpenter98
Price drop: $300
Christian Carpenter
Old 01-08-2022, 09:21 PM   #19
cwcarpenter98
Frame sold earlier today to a fellow forum member.
Yes, a 63-66 frame will stack on a 60-62 frame
Christian Carpenter
