06-07-2021, 10:03 AM | #1 |
Ram horn manifold
If anyone was wondering what size bolts to get for the OEM 350 exhaust manifold, the thread size is 3/16 24 and the middle size is 2 3/4. I found this through trial and error and I only found ONE bolt this size between Lowes, O'reilly, Napa, and Advance auto parts. I have lots of 3", so I'm going to have to cut them down. Apparently no one wants to run the original manifold anymore.
06-07-2021, 10:44 AM | #2 |
Re: Ram horn manifold
which bolts- manifold to cylinder head? They should be 3/8-16 thread size. I've never seen a fine thread manifold bolt and 3/16" diameter is much too small.
I've ordered manifold bolt kits from Corvette Central. https://www.corvettecentral.com/c3-6...f%3fcount%3d18
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
06-07-2021, 11:23 AM | #3 |
I run the original ram horn manifolds on my LT1 350 and use the stock bolts which are 3/8" x 16 national coarse thread. In all my 30yrs in garage work I've never seen a bolt smaller than 3/8" on a small block Chevy. If someone broke the original bolts off maybe they drilled and tapped them a smaller size. I would be worried about a 3/16" bolt not being able to hold the exhaust manifold in place for very long.
06-07-2021, 12:20 PM | #4 |
Don't forget to use anti-seize when installing the bolts , Someday you'll need those bolts to come out .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
06-07-2021, 01:03 PM | #5 |
Sorry everyone, I meant the correct length is what I'm having trouble getting. My 72 had headers and a terrible, too short exhaust when I got it. Going back to stock-type, so I didn't have the original manifold bolts to bolt to the engine, just the short ones for the headers.
06-07-2021, 03:10 PM | #6 | |
06-07-2021, 03:34 PM | #7 |
No thank you. I know the correct lengths, I just can't find them. I can get 2 1/2" and 3" length everywhere but I can't find 2 3/4" anywhere in grade 5 or 8. I have some 3" grade 8 in the right pitch so I'm going to try to grind the last 1/4" off and see how that goes.
06-07-2021, 06:17 PM | #8 | |
06-07-2021, 08:47 PM | #9 |
try ARP they usually have everything probably not cheap though
06-07-2021, 11:55 PM | #10 |
Fastenal has them.
06-08-2021, 01:08 AM | #11 |
06-08-2021, 02:37 AM | #12 |
McMaster Carr is another source.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
06-08-2021, 08:50 AM | #13 |
06-08-2021, 09:32 AM | #14 | |
https://www.mcmaster.com/hex-bolts/m.../length~2-3-4/ |
06-08-2021, 11:10 AM | #15 |
I've cut bolts off before and found that if you run a thread die down the bolt, make the cut, then unscrew the die, the burr come off and the bolt will thread into the head easier.
'71 C/20 350/T350. |
